08-27-2019 05:49 PM - last edited 3 weeks ago by ROGBot
08-27-2019 09:55 PM
08-28-2019 07:04 AM
FULLMETALJACKET7 wrote:
Run the laptop on battery until it's completely flat, then recharge it to see if goes back to normal. You can also reset the EC chip by holding the power button with the laptop off, until the leds starts blinking. If that doesn't fix it, it's very likely that you have a bad battery pack. The battery can go bad really fast when only one of it's cells are going bad. If you're curious if that's the case, you can discharge the battery to around 5-10% and measure its cells voltage individually using a multimeter. Be VERY VERY careful not to short it out. Don't touch it unless you really know what you're doing. The voltages should be pretty much the same all around.
08-28-2019 03:56 PM
08-29-2019 11:07 PM
