C7H + 3900x + 2x16GB OC@3733CL16 need help with stability
Vidati
I have used the Dram Calculator and managed to get my 2x16GB 3200CL15 to 3733 CL16.
Prime 95 fails after a while. initially i had the memory at 1.37v and now i have raised it to 1.4v but i still get errors.
What is the best way of getting the ram stable?
Thanks.
10 REPLIES 10
abaw001
Vidati wrote:
Thanks.
With prime 95 instead of memory its probably your cpu overheating. For testing memory use memtest, ramtest etc.
Dont think so, my CPU stays at 70-75c, cooled with H150 PRO.
And i used the memory test in Prime95, Large FFT's (Stress memory controller and Ram).
If i pass Memtest 1000% can i consider the memory stable?
Cheers.
abaw001
I don't use memtest but i'd say 1-2 hour minimum or leave it running overnight for best results.
Lothos
Vidati wrote:
Thanks.
I have it stable at 3733 with a 2x16 with CL14
What are you timings and ohms set to on the C7H? Also what is your sock voltage?
81651
I have used the DRAM outputs, it gave me 1.37v and it wasn't stable, i remembered reading that extra voltage can help so i upped to 1.4.
Vidati wrote:
81651
Try using profile V1 instead of manual. If you are using Samsung B-Die setting it to 1.45 volts should be fine.
C7H Bios the timing for the tRCDWR and tRCDRD are in reverse order from what you see in Ryzen calculator so I would first make sure you are putting those timings in the right place.
Yeah i did noticed, thanks.
So its 16-17-16-16, the thing is, i have been running this for the last 24h, i had some work done and played heaps of games, no issues so far and no crushes.
I would like to know if i have to pass prime for like 24h to grantee the stability of the system?
I did run Memtest (from DRAM Calculator) for about 1h and 30 min, passed 100% and more without errors, should i just keep it like this? or at some point i will encounter some stability issues? Difficult to know i guess.
andyliu
change the profile version to V1/V2 might provide you different timing and voltage
Also try safe preset first.
And I thought 3600Mhz is the sweet spot, maybe consider that too?
