Results 1 to 3 of 3
    New ROGer Array SDCGSB PC Specs
    SDCGSB PC Specs
    MotherboardCrosshair V Formula-Z
    ProcessorFX-6100/6300/8350
    Power SupplyCorsair 850W 80+ Gold
    OS Win10Pro
    Jun 2019
    6
    Crosshair V Formula-Z ROG Connect CPU OC multiplier issue
    Hoping someone can help out, exhausted troubleshooting this...
    I had over the past few months been having success overclocking an old FX6100 using ROG Connect.
    Pushing super hard I finally fried it and dropped another FX6100 in for another shot.
    When I did I found that all my OC controls seem to work but the multiplier causes windows to flash and lockup with even a small bump (16.5 to 17.5x).
    This has been a journey but I don't know what else to change/fix, The first install was not this complicated, also interestingly for some reason the boot SSD just works without issue right now, whereas the prior boot SSD needed some setting I never got my arms around and had to save into an OC Setting slot so I didn't lose it.
    During the course of troubleshooting I've:
    Blown the MOBO (good story/ugly) and replaced it (issue not resolved)
    Changed the boot SSD
    Changed the Power Supply (Gold to Bronze 80+)
    Changed the RAM
    Changed the Control PC
    Updated BIOS to 2201, Reverted to 2002, Back to 2201
    Loaded the USB updates
    Changed CPU's
    Reset CMOS, Recommended Settings, and back to basic OC settings
    Uninstalled and reinstalled ROG Connect
    Changed GPU
    Changed PCI-E slot
    Changed ROG Connect Cable
    Lots of messing with BIOS settings
    ...I'm Sure there's more
    Hoping someone has had the same issue or knows what setting needs to be corrected
    SDCGSB PC Specs
    OS Win10Pro
    Jun 2019
    6
    And On and on
    Installed rog connect plus on both computers... (again)
    Installed AI Suite on the CVFZ PC...
    Flashed back to original and mid life bios...
    Installed NVidia GEForce drivers and ran with my GTX 1060 6G...
    did find that the Ethernet port didn't work despite being enabled in bios,
    got sick of it and turned everything "on" and got it to work... ?
    ...ugh...
    SDCGSB PC Specs
    OS Win10Pro
    Jun 2019
    6
    and then...
    BTW, AI Suite works fine.
    I would just prefer not put that load on that PC.
    so to be clear the CPU at these settings will OC to a 18x mult stable...
    ...just not in/with rog connect ?? (Still/now)
    If one day it just stopped working for you, what would you expect it to be?
Tags for this Thread
