Results 1 to 2 of 2
    ROG Junior Member Array
    Mar 2018
    4
    FX503VD M.2 compatibility
    Hi.
    They lent me an ASUS FX503VD notebook and I would like to update the ssd disk, someone who understands more can tell me if this m.2 is useful .. ??
    https://shop.westerndigital.com/prod...sd#WDS250G1B0C
    THANK YOU
    New ROGer Array Khean PC Specs
    Khean PC Specs
    MotherboardROG Strix Z390-E Gaming Motherboard
    ProcessorIntel 9th Gen Core i9-9900K OC 5.0Ghz @1.320 Adaptive
    Memory (part number)Corsair Vengeance Pro RGB 2x16 32gb 3200mhz
    Graphics Card #1ROG Strix GeForce RTX 2080ti OC 11gb GDDR6
    Sound CardSupremeFX Onboard
    MonitorASUS ROG Swift PG279Q Gaming Monitor
    Storage #1Corsair Force Series MP510 M.2 NVMe PCIE Gen3 240gb
    Storage #2Seagate Baracuda 2TB Mechanical Hard Drive
    CPU CoolerCorsair Hydro Series H150i Pro RGB 360mm
    CaseCoolmaster Mastercae H500P Mesh
    Power SupplyCorsair RM 750x Gold Certified
    Keyboard HyperX Alloy Elite RGB MX Cherry RGB Red
    Mouse HyperX Pulsefire Surge
    Headset HyperX Cloud Alpha
    Mouse Pad HyperX FURY S - Pro Gaming Speed Edition Mouse Pad – Large
    Headset/Speakers Samsung HW-M360 Soundbar
    OS Windows 10 Pro 64bit
    Network RouterNetgear NigthHawk M1
    Khean's Avatar
    Jul 2019
    34
    33
    Quote Originally Posted by luis_jc View Post
    Hi.
    THANK YOU
    https://www.asus.com/Laptops/FX503/specifications/
    if that's your right model this is the compatible SSD compatible for you.
    Solid State Drives:
    128GB/256GB/512GB SATA3 M.2 SSD
    make sure you bought M.2 SATA3 ssd NOT the M.2 NVMe SSD. They are different lane structure.
