Results 1 to 8 of 8
    ROG Member Array
    Aug 2013
    5
    G752VY-DH72 battery replacement in USA
    My 2015 ROG's battery has finally died.
    I am trying to find a reliable replacement in USA. Tried 2 different ones on Amazon but both don't hold charge.
    I called ASUS USA and asked if they can ship me the replacement battery for out of warranty repair, to which they declined.
    The original battery part number is: A42N1520.
    Does anyone know where to get an OEM replacement battery in USA?
    Thanks.
    ROG Guru: Green Belt Array
    Nov 2012
    69
    733
    I purchase my replacement laptop batteries from Newegg.
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    ROG Member Array
    Aug 2013
    5
    Quote Originally Posted by jdfrench3 View Post
    Do you have a link for the product. Really appreciate. thanks
    Nov 2012
    69
    733
    You have broke fingers or what?
    Here's a Newegg link (sold by BattPit):
    https://www.newegg.com/p/16J-006B-11...B&gclsrc=aw.ds
    The last laptop (ASUS G1S) battery I got was from BattPit, was a very good battery.
    Hope your fingers feel better soon!
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    111
    4,174
    Quote Originally Posted by drneet View Post
    Hmm sounds like you issue might be more than battery if two didn't charge or hold a charge sound like and issue with the charging circuit??.
    Thanks.
    See comment
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Member Array
    Aug 2013
    5
    There are too many options. wanted to know which one can be trusted..Thanks
  7. #7
    ROG Member Array
    Aug 2013
    5
    Quote Originally Posted by Clintlgm View Post
    See comment
    If this one doesn't hold charge, then I'll look further into it.
    Thanks.
  8. #8
    ROG Member Array
    Aug 2013
    5
    Got this one instead.
    https://www.newegg.com/p/16J-00DV-00...9SIAH9B8ZH4542
    Seems to be working well so for. will update, if there is any change
    Thanks.
Tags for this Thread
