Fan Xpert 4 - Fan stops after boot
pk1209
Took delivery of my new rig yesterday, including a nice shiny Maximus XI Hero MB. Installed AI Suite 3 with Fan Xpert 4, ran the tuning, but since then once of my case fans switches off after boot (spins during boot). Have since cleaned out AI Suite completely (had the uninstall bug where it wouldn't let me uninstall) and reinstalled without Fan Xpert 4, but the fan still isn't spinning after boot?
Not really sure what to try next?
Thanks,
pk
4 REPLIES 4
mdzcpa
Level 12
If you ran fan tuning, they might have not been spinning because temps were low and you had silent mode checked. Under silent mode case fans can spin to zero when temps are down. Another thing might be what you set the case fans to react to. CPU temps, PCH temps, System Temps...etc.
If you do not want fan expert, set up the fans in the UEFI.
pk1209
Hi, that makes sense with Fan Xpert still installed, but it's the same after I've removed it?
pk1209
looks like i've been able to sort by resetting BIOS and going through fan setup from the beginning again 🙂
mdzcpa
Level 12
I had assumed Fan Expert left residual changes to the fan profiles in the BIOS. Glad to hear you sorted it.
