Results 1 to 9 of 9
    New ROGer Array
    Sep 2019
    4
    Rampage 5 extreme and NEW memory :)
    Hello rog friends! I need your help. I have rampage 5 extreme and 5930k. I want to order CORSAIR 32GB Dominator RGB DDR4 3200MHz CL16 KIT CMT32GX4M4C3200C16. I know its new generation memory and my hardware is few years old. Anybody tried this combination, I know x99 is not mentioned in compatibility list on corsair site. For me, its not MUST to run it at full 3200, I am ok with lower speeds too. Trident z rgb 3000 is compatibile with x99 but I prefer dominator RGB. Thank you all!
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS x99 sabertooth & x299 Rampage VI Apex
    Processori7-5930k & i9-9940x
    Memory (part number)Trident-Z 3200C14 & Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block & Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Coolerx99 2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 & EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum & Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Heatkiller 4 Pro copper plexi/Optimus Foundation copper plexi
    Accessory #2 Mayhems Biocide and Inhibitor with distilled water
    Accessory #3 Mayhems 3/8-5/8" clear soft tubing
    ThrashZone's Avatar
    Oct 2017
    23
    365
    I wouldn't
    I have 3200C16 trident z won't even post on x99 something about hynix or micron chips x99 hates at this high of frequency and loose timings 16-18-18-38
    3200C14 does how ever work very well b-die and all is all I can figure and tight timings 14-14-14-34
    Only CD memory worth getting if you really want the name is 3200C14 if they have it.
    New ROGer Array
    Sep 2019
    4
    I cannot find c14. But, will all of those new RAMs like dominator RGB, trident Z RGB work on at least 2666 speed on X99 chipset or that is under the question too?
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    23
    365
    Loose timings on x99 above 2800 is a coin toss
    I had CD 2666C16 and it worked pretty good though loose timings and all both xmp profile 1 and 2
    CD 2666C15 is total garbage on either xmp profile.
    The 5930k memory controller on mine was/ is pretty finicky
    I just manually set timings on 3200C14 and it just worked not to mention posted was the big cross my fingers deal
    Seriously though I wouldn't chance anything but C14
    https://benzhaomin.github.io/bdiefinder/
    This is the set I got forget the rgb crap
    https://www.newegg.com/Product/Produ...82E16820232348
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    23
    365
    Here's CD 3200C14 rgb 4x8gb kit yikes price wise though go for the non rgb trident z lol
    Also x99 does not have any rgb features and would likely not be able to use the feature anyway seeing that.
    https://www.corsair.com/us/en/Catego...2GX4M4C3200C14
    New ROGer Array
    Sep 2019
    4
    Are you sure RGB doesnt work on X99 platforms at all?
  7. #7
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    23
    365
    Does your board have any rgb ports on it ?
    Likely not x99 was before rgb craze started
    Look on your boards utilities section for AURA bet it's not listed if it is you should be good although you would be better off with tight timings.
  8. #8
    New ROGer Array
    Sep 2019
    4
    Quote Originally Posted by ThrashZone View Post
    My board doesnt have RGB ports. But my asus strix 2080 TI works with Aura RGB software without any problem.
  9. #9
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    23
    365
    Yep might work problem really is the C16 deal instead of C14
    Corsair's is stupid expensive just for rgb on C14.
