Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    New ROGer Array Xpoint PC Specs
    Xpoint PC Specs
    MotherboardMaximus XI Hero Wi-Fi
    Processori9-9900K
    Memory (part number)G.SKILL Trident Z @3200 Mhz (2x8 GB)
    Graphics Card #1RTX 2080 Ti Strix OC
    Sound CardSchiit Modi
    MonitorAsus MG 278Q using G-Sync compatibility
    Storage #1Samsung SSD 970 EVO 1 TB
    Storage #2WD Black 4 TB
    CPU CoolerNZXT Kraken X72
    CaseFractal Design Define R6 USB-C Blackout TG
    Power SupplyEVGA SuperNOVA G3 750
    Keyboard Fnatic Gear Rush G1 (formerly known as Func KB 470)
    Mouse Logitech G305
    Headset ModHouse Argon MK3
    Mouse Pad Corsair extended
    Headset/Speakers Swan M300
    OS Win 10 Pro x64
    Network RouterFritz!Box 7362 SL
    Accessory #1 Emotiva BasX A-100 headphone amp
    Dec 2018
    14
    Question What are the M.2 heat sinks made of?
    Hello there,
    I just bought a second M.2 SSD. It arrived today and I tried to install it to the lower M.2 slot of my Maximus XI Hero but the right screw won't come out. It sits so tight that I already completely rounded it out.
    Now I am not sure if I can save the lower M.2 SSD slot somehow.
    One way to save it would be to cut the heat sink covering the connector near the screw with pliers or something like that.
    But for that I need to know what the right black part of the lower heat sink is made out of. Is it a aluminum kind of hard material under the black plastic or is it maybe just plastic at the right end?
    Can someone maybe look at the back of your shield and check whether there is some harder material than the black plastic at the right end? That would be of great help.
    I bought this board a few months ago, so couls I return it and ask for warranty since the lower M.2 slot is not usable like that?
    Thanks for any help!
    ROG Enthusiast Array edrickjk PC Specs
    edrickjk PC Specs
    MotherboardASUS ROG MAXIMUS XI EXTREME
    ProcessorIntel Core i9-9900K
    Memory (part number)F4-4266C19-8GTZKW 8gbx4
    Graphics Card #1ASUS ROG STRIX RTX 2080 Ti GAMING OC 11G
    MonitorAcer predator X34P
    Storage #1Samsung SSD 970 EVO Plus 500GB
    Storage #2WDC WDS512G1X0C-00ENX0
    CPU CoolerEK-Velocity
    CasePhantek Enthoo Luxe 2
    Power SupplyCorsair HX1000I
    Keyboard Razer blackwidow x chroma
    Mouse Razer mamba wireless
    Headset SteelSeries arctis pro wireless
    Mouse Pad Razer Goliathus Control Extended
    Headset/Speakers Razer nommo chroma
    OS window 10
    Network RouterAsus RT-AC-5300
    Jul 2018
    66
    First , if it feel to tight or slip usually you have the wrong size screw driver. Second At this point the smart way would be to remove the board cover the area arround the shield and use a dremel to cut 2 slot in the screw. This way you will be able to use a larger Philips to remove it.
    Xpoint PC Specs
    Processori9-9900K
    Mouse Logitech G305
    OS Win 10 Pro x64
    Dec 2018
    14
    Quote Originally Posted by edrickjk View Post
    May be, but how am I supposed to know what size this screw needs exactly? And I don't think that a mainboard manufacturer should just expect their customers to have a set of small screw drivers at home just to install a SSD. And lastly there is absolutely no point in tightening these screws at all. Not after installing an SSD and certainly not in the factory.
    That might be the best way to do it but I never used one and I guess I would need a VERY small "blade" (don't know how these are called).
    And I can imagine that the vibrations from doing that may damage the board. And how to fixate a PCB? I can't just put it in a lathe.
    I still tend to just cut the cover near the screw. It'll be ugly but not really visible under the graphics card anyway.
    So it would be really great if someone could tell me what this shield is made out of.
    But thanks for sharing the proper way of dealing with it!
    edrickjk PC Specs
    OS window 10
    Jul 2018
    66
    shield is made of aluminum and you occur more chance to damage something cutting the heat sink then cutting to small slot with a dremel . Lay it flat on your motherboard box for ex,there no vibration,extreme shifting .
    https://www.youtube.com/watch?v=9PyXa1Irnys ,take a smaller cutting disk of course but it will work the same . Reason i say to cut 2 slot is to give you more leverage ,but you could try with just once,the important is not to cut to deep .
    Sep 2013
    36
    46
    You might also consider a "screw extractor" tool... they're designed for exactly this type of situation.
    Xpoint PC Specs
    Processori9-9900K
    Mouse Logitech G305
    OS Win 10 Pro x64
    Dec 2018
    14
    Quote Originally Posted by dingo99 View Post
    Yes, I thought about that too since I was in a similar situation just a month back and searched for ways hot to unscrew a stripped screw. I guess you mean one of these devices your hit with a hammer and then convert that force into a turning motion? Those are quite destructive and I won't dare to use these on a PCB.
    But I think I will just try that dremel thing out. I never did that but there is a first time for everything, ey?
    But what do you mean with "extreme shifting"?
  7. #7
    Sep 2013
    36
    46
    Quote Originally Posted by Xpoint View Post
    Hammer?? LOL, no, of course not. There are screw extractors that work with downward pressure and turning. For example, iFixit has a set for precision screws, but they don't make clear what sizes are included.
  8. #8
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    959
  9. #9
    Xpoint PC Specs
    Processori9-9900K
    Mouse Logitech G305
    OS Win 10 Pro x64
    Dec 2018
    14
    I had a look at them but they look like you would still use a hammer to impregnate the profile into the screw. Or do you think the screws on the board are soft enough pushing it down would be enough?
  10. #10
    Xpoint PC Specs
    Processori9-9900K
    Mouse Logitech G305
    OS Win 10 Pro x64
    Dec 2018
    14
    Quote Originally Posted by mdzcpa View Post
    Yes, but these screws are SO small, I doubt there are bits small enough for that...
    EDIT: and the problem with these is that they rely on friction, which is probable less strong that the profile of the screw in the beginning, so if that wasn't enough to loosen it, that probably won't work either.
Tags for this Thread
