(Solved)ROG Rampage Extreme Omeaga no post only clicks
sturm375
Hi folks,
Hope you can help me. Putting to gather a new PC with a new ROG Rampage VI Extreme Omega. On my first attempt at firing it up, the RGB lights would light up on the Mobo, and the LED screen on the Mobo would work. Whether I use the power button on the case, or the button on the mobo itself, I gete a few clicks as it tries to fire up, then nothing. None of the case fans light up. The Corsair AIO pump does not start up. I get no post, and once I try it then I no longer get those clicks when I use a power button. I've checked all the connections to the power supply. That power supply is a Corsair AX1200. I've removed everything I can think of to eliminate issues. It just will not post Could possibly be the mobo itself, though I hope not, I do not want to go through an RMA if I don't have to. GOing out to grab a new PSU and try that, but I am not hopful.
4 REPLIES 4
sturm375
SOLVED!
Turns out the Corsair AX1200 though it has enough power, it does not have the right cabling. New Corsair RM1000x solved the issue. :cool:
sturm375 wrote:
SOLVED!
Strange... I have an AX1200i on my system and two RTX 2080 Ti's Not had any issues with posting in regards of the Omega.
ASUS ROG RVIE Encore| i9-10940x | Dominator Platinum 128GB 3333 MHz | EVGA RTX 2080 Ti SLI | Samsung 970 Pro 1TB NVMe (x3)
WD Black 4TB | WD Black 6TB x2 | EVGA 1600 P2 | CaseLabs SMA8 | Custom Water Cooling | HWLabs Black Ice Nemesis GTX 560
XSPC RX 480 v3 | XSPC D5 Vario x2 | EK Blocks | EK-RES X3 400 | BitsPower Fittings | GentleTypoon 1850 x12 | Corsair SP140 x8 | Lamptron CM615
Twitch.tv/MsNikita | Twitter.com/MsNikitaTV | Instagram.com/MsNikitaTV | Reddit.com/r/MsNikitaTV
Not suprised. AX1200i will have different outputs than my older AX1200 (no "i").
Well glad you resolved it
