Results 1 to 3 of 3
    New ROGer Array
    Sep 2019
    1
    Dual Channel issues with 3700x
    Is anyone else still experiencing the C5 error when trying to boot with dual channel RAM? With Bios 2501 I could SOMETIMES boot with dual channel. But with 2703 I can only boot with a single stick in the furthest slot from the CPU. Any suggestions on a workaround perhaps?
    ROG Member Array YabaX PC Specs
    YabaX PC Specs
    MotherboardRog Strix X570 Gaming-F
    ProcessorAMD Ryzen 3700X
    Memory (part number)G.Skill Tridentz Royal 3600 (OCed 3800)
    Graphics Card #1Rog Strix 1080 Ti OC
    Sound CardOnboard Supreme FX
    MonitorAsus MG278Q -27" Freesync - 1ms
    Storage #1Samsung 970 Evo Plus Nvme
    Storage #2Bunch of SSDs + 7 TB HDDs
    CPU CoolerCooler Master ML240R ARGB AIO
    CaseCooler Master Cosmos C700M
    Power SupplyEVGA G2 1000W Gold
    Keyboard Corsair K70 RGB
    Mouse Steelseries
    Mouse Pad Corsair RGB
    Headset/Speakers 5.1 Creative
    OS Windows 10
    Network RouterAsus RT-AC3200
    YabaX's Avatar
    Nov 2014
    9
    make sure to install your ram into A2* and B2* slots, check the user manual
    New ROGer Array RSFoxx PC Specs
    RSFoxx PC Specs
    MotherboardAsus Crosshair VII Hero
    ProcessorAMD Ryzen 3700x
    Memory (part number)F4-3200C14-8GTZN
    Graphics Card #1Asus ROG Strix RTX 2080 OC
    Storage #1Samsung EVO 970 NVMe M.2 256GB
    Storage #2Crucial MX500 2TB
    CPU CoolerCorsair H115i Hydro Pro
    CaseNZXT H700
    Power SupplySeaSonic X-Series 850w 80+ Gold
    Keyboard Corsair Strafe MK.2 Silent
    Mouse Corsair Glaive RGB
    Headset Corsair Void Pro
    OS Windows 10
    Accessory #1 Audio-Technica AT2020 Microphone
    Aug 2019
    12
    Quote Originally Posted by Poloskie View Post
    If the ram is set in correct slots, with bios 2501, you have to set the ram boot voltage in Digi+. It should match DOCP or whatever ram voltage you use. It was a bug with that bios version.
