RX5700XT-STRIX-O8G minor issues
Shane_x86_64
Hi all,
Just wonder if anyone here using this video card has the same issues as I do with the ASUS softwares. To start GPU Tweak II refuses to start. It was working just find with GTX1080, but now I get:
Faulting application name: GPUTweakII.exe, version: 2.0.5.0, time stamp: 0x5d537712
Faulting module name: Exeio.dll, version: 1.1.2.1, time stamp: 0x5d4a52ba
Exception code: 0xc000041d
Fault offset: 0x00004fd0
Faulting process id: 0xdfc
Faulting application start time: 0x01d56a3cf2120faf
Faulting application path: C:\Program Files (x86)\ASUS\GPU TweakII\GPUTweakII.exe
Faulting module path: C:\Program Files (x86)\ASUS\GPU TweakII\Exeio.dll
Report Id: 7d3c7b6b-590d-4ae5-af0c-1d5269f2e4aa
Faulting package full name:
Faulting package-relative application ID:
in Event Viewer. Tried complete uninstall resinstall nothing helped. The other issue is the lightning control. I can control GPU lights through the old AURA RGB Lightning Control software but Aura Sync won't detect the GPU at all. I have updated everything, tried all downloadable versions of aura sync, nada. Otherwise the card functions properly. Any tips?
americorlolivei
Shane_x86_64 wrote:
Hi all,
Hi
I have this card and can run gpu tweak II fine.
I use armoury crate for the lightning an it works
americorlolivei
Hi
Steve from Hardware Unboxed
In this video at 8:30 he says that Asus identify a problem with the power draw on the Asus Strix RX5700XT OC and will release a new bios
https://youtu.be/OJU8jKIYtS4?t=510
has anyone had access to this bios?
