Results 1 to 4 of 4
    ROG Member Array
    Feb 2019
    19
    ROG RYUJIN 360 issues
    I'm struggling to control a ROG ryujin 360 with Armory Crate software. After restarting the PC, the Smart Mode profiles will not be saved. The speed does not increase under load.
    Radiator 360 image:
    Pump micro fan image:
    Thank you for the answers.
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    28
    1,833
    Quote Originally Posted by Loadlineac View Post
    Radiator 360 image:
    Thanks for the info. Yes i detect these on last update. I send the report back. I detect these on mine, since every time i turn on the computer the Aio stay on default. and I have to manually set it up on start or restart getting in on the crate. Bug send for investigation.
    Learn, Play Enjoy!
    ROG Member Array player678 PC Specs
    player678 PC Specs
    MotherboardAsus ROG MAXIMUS XI EXTREME
    ProcessorIntel Core i9-9900K
    Memory (part number)G.Skill Trident Z RGB 32 GB
    Graphics Card #1Asus GeForce RTX 2080 Ti ROG Strix OC
    MonitorAsus ROG Strix XG35VQ 35.0"
    Storage #1Samsung 970 EVO Plus 2 TB
    CPU CoolerAsus ROG RYUJIN 360
    CaseCooler Master MasterCase H500M
    Power SupplyAsus ROG Thor 1200W
    Aug 2019
    Armory crate update - livedash issues
    I was also struggling with this update and it has more configuration issues:
    1. Live dash utility no longer works to configure displays of both XI extreme and of Ryujin.
    2. The configuration of displays is saved, but when PC restarts you have to manually open the configuration screen for it to restore
    3. Choosing Ryujin config page also breaks Aura config for Ryujin - you have to reopen Aura effects for them to be enabled
    On top of that there are several issues with the config itself:
    1. Temperature/CPU Temp monitor shows different CPU temperature from AI Suite (the latter is 10-12C lower)
    2. Voltage/PCH Temp monitor shows some voltage (not sure which), PCH Temp is not available at all in the temperature section
    3. Fan/CPU Temp shows pump speed (with the correct icon at least on Ryujin)
    4. You can monitor temperatures of cores 0-7 (in i9-9900K), but you can only see frequencies of cores 1-7
    This release is quite bad, to be honest, but unfortunately there is no fall back to Live dash
    For Ryujin fans though (both radiator and pump), you can still use AI Suite, at least for now
    Looking forward to the fixes - hopefully with more QA this time.
    EDIT: Actually, sometimes livedash settings are restored after restarting (or maybe it updated?) But the aura settings for Ryujin are still lost - it's not synchronised.
    EDIT 2: It continues to fail on some restarts
    MrAgapiGC PC Specs
    Processor9900K
    CaseNzxt H700
    Mouse Asus Spartha
    MrAgapiGC's Avatar
    Nov 2011
    28
    1,833
    Quote Originally Posted by player678 View Post
    That i can confirm. I send these 2 days ago. I also wake up with a non funcional application. I did the xml delete, restart the service and restart the computer and start working.
    The part of the AIO is happing algo that on computer restart the aio return to default operation, and only get fix going to the app and manually start working. I detect these 1 week ago. There 2 situation that I detect. IS WINDOWS. since there is a COM trigger that is present. But Since i am not a savy guy in that area, I send the data. Let see what will happens. I will check another install by Monday and see if recurring.
    Learn, Play Enjoy!
