GL704GM Power Throttling
TheAlphaOmega1
GL704GM:
CPU: i7 8750H; [2.1 - 4.1 GHz]
GPU: GTX 1060 6GB
256 NVMe SSD + 1TB HDD 5400 RPM;
BIOS ver. 308;
Windows build 1809;
Problem:
When running Stability test on AIDA64 with FPU + GPU as well as CPU + GPU, both seem to be running on their best available pefrormance for around 30-40 seconds and right after that, CPU hits "Power Limit", after which Core Clock as well as Temps go down. Biggest concern is that CPU stops running as fast as it should which decreases performance drastically. My temps hit 90-95C, and while I understand it is pretty high, I am planning on repasting and figuring a way to deal with such high temps, however, Thermal Throttling does not explain Power Limit Throttling.
Screenshots:
ilolminati
Solution and conclusion: https://rog.asus.com/forum/showthread.php?111150-GL504GS-helpful-fix-for-heat-throttling-while-gamin...
they deceived us and sold us laptops with a CPU that can have a clock speed of max 3.6Ghz, so that it does not overheat...
