Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    New ROGer Array
    Feb 2019
    14
    ROG Maximus XI Extreme Rev 1.02 BIOS: 1105 issues
    Hardware:
    Board: ROG Maximus XI Extreme Rev 1.02 BIOS: 1105
    RAM: 16GB G.Skill Trident Z RGB DDR4-3200 DIMM CL14 Dual Kit (F4-3200C14D-16GTZR)
    3 pictures:
    I do not know if it's BIOS Bug, or if it's overclocking.
    So if I set the "CPU VCCIO Voltage" and "CPU System Agent Voltage" to a fixed value, then the board shuts down twice, then it starts normally and sets automatically: VCCIO = 1.35000. VCCSA = 1.35000. DRAM Voltage = 1.4000.
    But if now: VCCIO = Auto and VCCSA = Auto is set, everything runs smoothly again!
    The i9 9900k runs Prime95 / Game stable with VCCIO = 1.136V and VCCSA = 1.072V, stable at 3200Mhz. ((Samsung B-Die dual ranked))
    I've tightened the timings to 13T-13T-13T-31T-320T-2T and needed a DRAM voltage of 1,500V to stay stable.
    I think that's just one of the latest BIOS versions.
    Can someone test it?
    Thanks for the answers.
    New ROGer Array
    Feb 2019
    14
    One more thing,
    If I increase the PC case airflow, then the board will not turn off. If the fans are running quietly and slowly, the board switches off again.
    All this makes no sense. It can not be a temperature problem, the VRMs are under load at 40 - 50 ° C. But since that happens at the POST should - can be a BIOS bug!
    Sensor data:
    ROG Guru: White Belt Array
    Aug 2013
    107
    The 1st post. There is a memory OC issue (today any XMP is OC). If BIOS find any problems during memory training performed during POST sets these voltages itself (in most cases to high). This issue may vary from Bios version to version. For example in my rig with Bios 0602 there is no problem, but with 1302 (and many others) I get MemOk warning during POST. Try to manually set Vram to 1.36V or around.
    The 2nd post. Strange, but it may be related to voltage controller on MB. In my case, when I had all case fans connected to case controller, there weren't MemOK! during post, but when I connected them directly to MB, I've started to get MemOk! issues...
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    17
    1,662
    interesting. I install my codexi last bios, like .... 2weeks now. I do not have the issue with the XMP. BUT! i did feal odd that my fans are not ramping as it should. Temps are in check and fans are spinning. I remember that fans where more notice.
    It is my understanding that asus will push a new bios and chipset soon for ours. No idea when. But OEM driver has to be updated
    Learn, Play Enjoy!
    New ROGer Array
    Feb 2019
    14
    Quote Originally Posted by cniedzi View Post
    In my setup, all chassis fans are connected to a fan expansion card, from which only the 4 pin PWM cable goes to the "CHA_FAN2" connector of the board. So only "CHA_FAN2" on board is occupied, nothing else. And that only because of the speedometer signal.
    New ROGer Array
    Feb 2019
    14
    Quote Originally Posted by MrAgapiGC View Post
    Have you already run Qfan Tuning in the BIOS?
    You can also set the profile to manual for the respective fan in the BIOS and adjust the entire profile.
  7. #7
    New ROGer Array
    Feb 2019
    14
    Ram solved problems
    Could solve the RAM problems. (Mem OK!)
    1. BIOS flashed to 1302
    2. "Round Trip Latency" = Enabled
    3. "Rank Margin Tool" = Enabled
    4. "Trace Centering" = Enabled
    5. "Dram Current Capability" = 130%
    6. "DRAM Voltage" = 1.450V
    7. "DRAM Frequency" = DDR4-3600MHz
    8. Timings on Maximus Tweak = AUTO, 15-15-28-2N, the rest on AUTO
    9. "Skew Control" and "RTL IOL Control" all on AUTO
    The IMC goes down at more than 3600MHz and dual ranked, or it is due to the RAM modules. (A not so good Samsung B-kit)
  8. #8
    Aug 2013
    107
    Quote Originally Posted by Loadlineac View Post
    where did you get these settings from?
    PS. I think 1.45V is far too much for 3600MHz...
  9. #9
    New ROGer Array
    Feb 2019
    14
    From myself and I-Net.
    Still being tested ...
  10. #10
    Aug 2013
    107
    Target for 3600MHz should be 1.35V...
