Best CPU cooling solution for AMD Ryzen Threadripper 1950X
Alexauwa
Hey guys,
I plan to buy my first AMD system primarily for 4k video editing with Adobe CC Premiere Pro and After Effects.
I've looked into varias air and water cooling solutions. I am not really into building a own system. Just into complete cooling hardware. Do you have any recommendation? I might plan to have a slight overclocking running with that setup.
Thank you! :cool:
Alex
RedSector73
Level 12
Coolermaster have won my dollars because they last well, 6 years for my first AIO pump to die. Corsair AIO made 4.5 years and death of pump was an explosion.
This looks good and i've used there non AIO model (on a old 980x for nearly 8 years) and it had excellent cooling.
https://www.coolermaster.com/catalog/coolers/cpu-air-coolers/wraith-ripper/
This is what I would want
https://www.coolermaster.com/catalog/coolers/cpu-liquid-coolers/masterliquid-ml360-rgb-tr4/
Have nothing bad to say about there products. Good pricing / Quality / Last. Cant say anything about there warranty never needed it.
Typically I use noctua fans in addition to push or pull air through radiator, they have low noise and high trust value for never dieing, got some of them over 12 years ugly as but still going.
