Results 1 to 4 of 4
    New ROGer Array Veggim PC Specs
    Veggim PC Specs
    Laptop (Model)Strix Scar edition
    MotherboardGL703GM
    Processori7-8750H
    Memory (part number)16GB RAM
    Graphics Card #1GTX 1060
    Sound CardRealtek High Definition Audio(i think)
    Jun 2019
    2
    Need help with GL703GM blue screens
    My GL703GM keeps getting blue screens for some reason and I haven't downloaded that much things. Except for roblox, roblox studio, and aura sync. And I have an acer mouse. This was the first gaming computer I brought and it keeps having this problem. Right now it just crashes and restarts, but no blue screen pops up.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,474
    It might help to do some testing. Does it happen at idle or under load when you're playing a game? You might try running some benchmarks to induce a crash. Also, you can run HCI Memtest to see if you get memory errors.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Enthusiast Array
    Feb 2019
    28
    50
    Quote Originally Posted by xeromist View Post
    No issue here. I have GL703GM.
    Try to re-install the latest version of Windows 10.
    Use the latest drivers. Update your BIOS.
    New ROGer Array
    Oct 2019
    29
    Quote Originally Posted by GeoBRB View Post
    When you are using laptops keyboard does it tend to crash when you press a keyboard key around the area of letter T?
    If so your problem is physical in nature. A shielding "tape" is missing inside your laptop and the pushing of your keyboard creates a shortcircuiting on the motherboard which can fixed in 30 minutes by opening the laptop and adding some electrical tape to the correct places. If you are newbie in laptop maintenance this can be a hard task. Please do this only if you know what you are doing. Otherwise you can always do rma and wait propably months to get your laptop working
