Results 1 to 1 of 1
    ROG Guru: White Belt Array AgentHunk's Avatar
    Jul 2018
    88
    Arrow Win10/GL702ZC HID Keyboard Device Issue
    Asus HID Keyboard Device Issue /and related sound effects when code 19 happens.
    I am using the ASUS GL702ZC laptop and was manually going through Device manager updating everything...until I cam across the keyboard section.it also causes my keyboard to stop working.....not one type key pad works when this installs from Device Manager and then the odd sounds adjustments...from before when I tried this install months ago...now that I see it isn't fixed...
    I want it fixed....
    I have dealt with it before but fixed it by rolling back.
    the only good news is System Firmware was the only driver I found that needed a update.
    Unfortunately Just rolling back isn't good enough...The issue happens when updating to the next driver and this happens....
    question?why is the update driver option corrupt?happens everytime I manually select and update in Device manager.....
    This also effects the audio Drivers installed with this Specific Model and System by Asus.
    Realtek HD audio manager and Sonic studio II.
    IDK why and frankly I care a great deal and want to see it fixed..
    photo of before install:
    before in the past I remember the HD Realtek Audio Drivers and Sonic also being affected at times...in my pc....
    but right now I am not noticing it since I rolled back the driver.
    these programs get affected by this install corruption when updating.
    Please fix this ASAP
