Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    ROG Enthusiast Array Brockmonster PC Specs
    MotherboardRampage VI Extreme Encore
    ProcessorI9 10980XE
    Memory (part number)G.SKILL F4-3200C14Q-32GTZ Trident Z Series 32 GB DDR4 3200 MHz
    Graphics Card #1EVGA Hydro Copper GTX 2080TI
    Graphics Card #2EVGA Hydro Copper GTX 2080TI
    Sound CardCreative Sound Blaster ZxR PCI-Express
    MonitorSamsung 32"
    Storage #1Samsung 970 PRO Polaris 512GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive
    Storage #2Samsung 970 PRO Polaris 512GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive
    CPU CoolerEK Water Blocks EK Encore Full coverage
    CasePhanteks Enthoo Elite Super Tower Case - Black
    Power SupplyEVGA 1600w
    Keyboard Corsair CH-9127014-UK K95 Platinum RGB Rapid Fire Cherry MX Speed Multi-Colour Backlit Mechanical Ga
    Mouse Corsair Gaming CH-9302111-EU Glaive RGB Multi-Colour Backlit Performance 16000 DPI
    OS Windows 10 X64
    Network RouterASUS RT-AC3200 Tri-Band Wireless Gigabit Router with USB 3.0
    Accessory #1 2 x 480mm push pull 1 x 240mm push pull
    Accessory #2 2 Custom loops, 2 x D5 Pumps, Solid Brass nickel plated tube
    Accessory #3 6 x Corsair XTI 480gb SSD`s, Aquaero 6 XT, 3 x Poweradjust 3 USB, ultra version, 2x Flow sensor hig
    Aug 2015
    11
    61
    Rampage VI Extreme bios 2002 issue
    Well I took the plunge and flashed to bios 2002 from 1503, 1704 and 1902 plagued me with random system lockups so I was hoping that 2002 resolved the issue.
    How wrong was I well saying that all was good for 10 minutes then a random system lockup. I have tried setting the memory settings manually with no joy.
    XMP is a no go zone and manually setting everything was the same. After changing settings for most of the afternoon I noticed that when the memory voltage was on auto it was it was ramping it up to 1.500v ?? It should be 1.350v so I set it manually and I could not get the system to boot for love nor money with the memory at 3200Mhz and again everything was in manually.
    At this point I was giving up the will to live so I left the memory voltage on auto to get it to boot in to windows and ran some bench test with AID64 and all was good.
    I will add that prior to all of this I had ran Memtest86 using bios 1503 and all 4 tests completed with no errors.
    After using the pc for about 30 minutes my screen went blank ?? after moving the mouse around the screen my short cuts came back as the curser moved over them?? so I refreshed the screen and everything was back. I put this down to a memory issue and put the memory back to default settings along with the voltage on auto which was showing 1.200v which are correct for default.
    one other test that I did was I went in to tweakers paradise to the bottom of the page and changed the DRAM eventual voltage to 1.350v for A,B,C.D along with the memory settings put in manually, this then showed the voltage in extreme tweaker at 1.350 when it was set to auto and not the 1.500v showing before but again I was unable to get the system to boot
    My memory is
    G.SKILL F4-3200C14Q-32GTZR Trident Z RGB Series 32 GB (8 GB x 4) DDR4 3200 MHz PC4-25600 CL14 Dual Channel Memory Kit which is on the QVL list.
    I have switched back to bios 1 which is 1503 where I have no issue with voltages or XMP, any help guys because I'm completely stumped
    Phanteks Enthoo Elite, Asus Rampage VI Extreme Encore, Intel I9 10980XE, G.SKILL F4-3200C14Q-32GTZ Trident Z Series @3200, 2 x EVGA Hydro Copper GTX 2080TI, Creative Sound Blaster ZxR PCI-Express Sound Card, EK ASUS ROG R6EE RGB Monoblock, 2 x Samsung 970 Pro 512GB Direct to CPU, Aqua Computer kryoM.2 with Samsung 960 Pro 512GB PCIe slot 4, 4 x Corsair XTI 480GB SSD, Aqua Computer Aquaero 6XT, 2x Aqua Computer D5 NEXT pump with Aquabus interface, 2 x XSPC 480mm Rads, EVGA 1600w PSU and more
    ROG Guru: Green Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME
    ProcessorIntel Core i9 7980XE 2.6GHz
    Memory (part number)64GB GSKILL 3.2 GHz 16-16-18-36 2T
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG UD590D
    Storage #1SAMSUNG 970 EVO PLUS 1TB x 3
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 10 2021 Insider Preview 20257.1005
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    51
    596
    Let's trying F5 Load Optimized Default first, Then setting CPU overclock profile to "XMP" after that retest stability via your tools such AIDA64 stress test , Realbench 2.56 or Memtest86 agains .
    Core i9 7980XE / R6E 3201 BIOS / Intel 02006A08 MCU 2020-06-16 / VROC VMD 7.5.0.1030 / RST 18.0.0.4897 / ME FW 11.12.80.1734 DV 2040.100.0.1029 / 64GB GSKILL @3.2GHz 16-18-18-38 2T / POSEIDON 1080i GTX + NVIDIA Driver 465.12 WHQL / / 3 x 1TB SAMSUNG 970 EVO PLUS + OMS Driver 18.30.1.1138 WHQL / Microsoft Windows 10 Version 2004 Build 20262.1010 / i219 V PHY UNDI OROM / Boot Agent 0.0.29 / 0.1.16 / 12.19.0.16 WHQL AQC 107n FW 4.2.32 + AQC 2.2.1.0 WHQL. CAM 4.15.0 Realtek HD 6.0.9045.1 WHQL
    ProcessorI9 10980XE
    MonitorSamsung 32"
    OS Windows 10 X64
    Aug 2015
    11
    61
    Quote Originally Posted by restsugavan View Post
    Hi Restsugavan thanks for the reply
    Ok I have loaded optimized defaults and had no issue with lockup so I have then overclocked the CPU 42% to 3700MHz with the memory at default 2133@ 1.200v with no issue after running AID64 or Realbench.
    If I select XMP 3200 14,14,14,34,2T bios auto sets the voltage to 1.500v which is wrong, it should be 1.350v. Now I have tested it at that voltage and speed but the screen goes blank after about 10 minutes and I need to refresh it to get it back.
    I have even tried setting it to Manual and entering the timings and voltage to 1.350 with no joy, system lockup. Is this a memory incompatibility issue despite it being on the QVL list or is it something I'm missing.
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Sep 2017
    51
    596
    Lightbulb It may cause DDR4 timing setting
    Let's checking your overclock profile first. When you selecting " XMP " like this picture it must read your GSkill DDR4 kit its XMP Profile for checking first.
    After setting "XMP" Profile above. Verify your DDR4 kit timing and voltage its used via BIOS menu before hit F10 to save setting and exit.
    If you setting the above menu completely. Your system must running smoothly.
    There are many kind of GSkill DDR4 3200 kit around the markets. Some designed for Intel XMP 2.0 platform. Other designed for AMD Ryzen platform.
    Both are the same speed and timing like DDR4 3200 16-18-18-38-2T but there will be any compattible issues when combine those kits together for
    your system. Due the same speed and timing kit may not use DRAM IC chip same manufacture.
    (Samsung B-die may not happy to working with SK Hynix parts or Micron parts due different design and yields)
    To ensure that it will not bring any problem to your rigs, you must choose quad channal kits and testing it before combine them better.
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS z490 maximus XII Apex 2nd x299 Rampage VI Apex
    Processori9-10900k & i9-9940x
    Memory (part number)Trident-Z 3600c16 2nd Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block 2nd Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 2nd EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum 2nd Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 ModmyMods clear coolant
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    23
    389
    Real easy to test
    You have dual bios correct
    If 2002 acts weird try 1705 on the other bios and see if it acts weird too
    F4-3200C14Q-32GTZRX is the AMD optimize product
    http://www.gskill.com/qvl/165/167/15...4Q-32GTZRX-Qvl
    OP does have a compatible set for his board
    http://www.gskill.com/qvl/165/166/15...14Q-32GTZR-Qvl
    B-Die rules but may be best to manually set timings and try T1 not T2 after clearing CMOS !
    It's well known RGB kit are funky to say the least you give up performance for looks never a good exchange
    Your non RGB set I have this set on x99
    https://www.newegg.com/g-skill-32gb-...82E16820232348
    3600C16 B-Die on x299 works fine for the most part but I do not use xmp profile just manually set and tune for best performance.
    Might as well get used to manual timing 4000 MHz++ will need tuning anyway but 3200C14 is a lot closer to getting 4k than any hynix or micron kit
    If you want to see some 3200C14 timings to compare yours with here's mine asrock mem config list
    https://rog.asus.com/forum/showthrea...790#post785800
    If you want some 4k scroll up to post 13 on the same thread.
    ProcessorI9 10980XE
    MonitorSamsung 32"
    OS Windows 10 X64
    Aug 2015
    11
    61
    Hi Restsugavan
    I set XMP for the memory and set multicore enhancement to Auto. checked the timings and manually set the voltage to 1.35v. it locked up during the AID64 test.
    One thing is bugging me about the voltage because it shows 1.36v on the left side of the manual setting of 1.35v so I set it to 1.34 which gave me 1.3480 on the left so I ran AID64 and it passed
    I ran Realbench and it locked after 8 minutes so again I set everything manually and it still locks up. now I have reverted back to default 2133 1.200v were there is no issue.
    Think its time to bin the memory and find something that works as stated.
  7. #7
    ProcessorI9 10980XE
    MonitorSamsung 32"
    OS Windows 10 X64
    Aug 2015
    11
    61
    Thanks ThrashZone I will take a look
  8. #8
    ROG Guru: Green Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    501
    Just installed bios 2002 and so far no problems, ran realbench, score 287.
    CPU at 46
    Memory at 64gb 1.35v 3600mhz 15,15,15,36 ( 8 x 8gb)
    First time a bios has worked out of the box for me.*
    Temperatures lower than 1902 but that could be influenced by ambient temp?*
  9. #9
    ProcessorI9 10980XE
    MonitorSamsung 32"
    OS Windows 10 X64
    Aug 2015
    11
    61
    I've been messing with memory timings for the last 8 hours and still no joy passing Realbench on 2002
    ThrashZone I have tried your settings in the link and it looks like a no go so I have 3 options
    option 1 run at default 2133
    option 2 switch bios back to 1503 and run at 3200
    option 3 bin the memory and get some G.SKILL F4-3200C14Q-32GTZ or even 3600 GTZ and forget about RGB
  10. #10
    ProcessorI9 10980XE
    MonitorSamsung 32"
    OS Windows 10 X64
    Aug 2015
    11
    61
    Rob W. what model memory do you have if you don't mind me asking ??
