Results 1 to 2 of 2
    New ROGer Array
    Oct 2019
    4
    Where is LiveDash? Why can I not update my Ryujin AIO in Armoury Crate?
    After a lengthy software installation in my new PC build including a ROG Ryujin 360 AIO cooler, I tried updating the Ryujin software so I could control it inside Armoury Crate, or maybe get access to Livedash. Unfortunately, Armoury Crate keeps telling me to restart my computer after an update, and then tells me I still need to do the update after a restart. It's an endless loop. Also, I can't find this LiveDash software anywhere. ASUS support told me to uninstall Armoury Crate and reinstall, to see if that would fix it. Unfortunately all that did was break Armoury Crate completely, now it will not recognize my Crosshair VIII Formula motherboard either, and doesn't have Aura Sync functionality anymore. I ended up having to wipe my system drive completely and start from scratch to get Armoury Crate working again. Now, after this fresh Armoury Crate install on a fresh install of Windows 10, I am still getting the issue where I can't update my Ryujin 360 AIO cooler, and now I have to reinstall all my other software to boot. ASUS support is no help to me, their escalated level of support is only available when I'm working. Anyone have any ideas for me?
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    17
    1,693
    Quote Originally Posted by polyh3dron View Post
    We all ready have send the report, for that particular situation and a update is on the works.
    But is on the works.
    I will send the note on the ROG Discord as soon these is ready and tested.
    And there is another points needed to address and also reported as well. Like GPU lights goes to slow and non workable when using netflix or stream apps. even that the game mode is off and also but limited on apps when browsers. You will see it that gpu lights are slow clumsy. When that happens, part of the aura seccion miss work.
    Also 3 new modules are in on specific and limited peripherals list
    Just be patience is a complex app and need to be tune since also is beta... very. i am sending all the data telemetry and possible workarounds and fixes to Dev in HQ. I do not wotk with asus, but i am giving the hand since i want to see these perfect.
    Learn, Play Enjoy!
