Results 1 to 7 of 7
    New ROGer Array
    Sep 2019
    5
    Question STRIX 2070 super leaking oil?
    Hi, I recently bought a new strix 2070 super.
    I immediately noticed that at startup the fans make a really loud noise, but I assumed it was normal.
    Then, after less than a week, I noticed some liquid droplets at the GPU's height on the inside of my side panel. So I opened it to investigate, and noticed that one of the fans was literally leaking oil, spraying it on my components when spinning.
    I don't think that's normal, what should I do?
    New ROGer Array
    Oct 2019
    1
    You need a specialist.
    New ROGer Array
    Sep 2019
    5
    Quote Originally Posted by Goodyni View Post
    Uh? what do you mean?
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    94
    2,432
    RMA It Take it Back Where You Bought It
    New ROGer Array
    Sep 2019
    5
    The seller said that I would need to cover the shipping, and that's money I don't have right now as the gpu weighs quite a bit and it would cost too much.
    toronto699 PC Specs
    Processori7-4770K
    Storage #1118 GB/OS
    Storage #22.72 TB
    CaseG30AB
    OS W 10
    Aug 2014
    94
    2,432
    Send It To Asus RMA It Then
  7. #7
    New ROGer Array
    Sep 2019
    5
    I contacted support and they told me to talk to the seller! They said that they can RMA it only after 2 years have passed.
    Did I do something wrong? Is there a way I can RMA it with them immediately?
Tags for this Thread
