10-09-2019 08:04 AM - last edited on 03-06-2024 07:35 PM by ROGBot
10-09-2019 07:16 PM
10-10-2019 08:10 AM
RedSector73 wrote:
If the fan was faulty it can draw excessive amount of amps which would melt the cable and put stress on your motherboard..... I would be looking at it, did the fan get hot as well, did it spin up to full / rated speed ?
How many amps does the fan draw.... How long is the extension cable ?
10-10-2019 04:36 PM
BjFaeTorphins wrote:
... Noctua NF-A14 rated at 0.55A connected to the fan extension card by the cable supplied with the fan.
10-11-2019 12:06 PM
RedSector73 wrote:
I only ever had one defective Noctua fan in 15 years and it didn't spin what-so-ever from first use and got hot, still amp draw was never enough to melt anything. I can also say I have fans of theirs over 8 years still running 24/7.
I have taken a look at your manual and noticed this is the most likely problem, that the header your using, isn't correct one for fan input. See diagram below I suspect your using the wrong header.
10-11-2019 03:13 PM
10-14-2019 06:17 AM
RedSector73 wrote:
What Fan Extension Card are you using ?
