Results 1 to 6 of 6
    New ROGer Array
    Aug 2019
    3
    Z370-E Gaming LED problem
    Hello guys, my Z370-E Gaming motherboard has been working fine, everything lit up until several days ago after a power loss, I/O shield LED stop working, both LED header stop working as well, I checked the power output at LED header with multi-meter and there is no power there, the addressible and RAM working just fine. I talked to ASUS support they told me tried to install windows, I did a clean install and nothing work. I also search around on the internet for the solution, tried uninstall AURA, checked the IO shield connector (which look fine and tight) ... I am basically ran out of idea. Anybody have any tips to share? I really appreciate it
    ROG Guru: White Belt Array Enderwiggin03 PC Specs
    MotherboardROG STRIX Z390-E Gaming
    ProcessorIntel Core i9 9900k @ 5.1Ghz on all 8 cores 1.355v
    Memory (part number)F4-4266C19D-16GTZR @ 4000Mhz CL16-17-17-35 1.45v
    Graphics Card #1EVGA RTX 2070 XC Ultra
    Sound CardCreative Sound Blaster X AE-5
    MonitorASUS VG248QE
    Storage #1Samsung 970 Evo 500GB m.2
    Storage #2Samsung 860 Evo 1TB SATA
    CPU CoolerEVGA CLC280 with 4x NF-A14 iPPC-3000 PWM (push/pull)fans
    CaseFractal Design R6
    Power SupplyEVGA G3 1000w
    Keyboard Logitech G513 Carbon
    Mouse Logitech G703
    Mouse Pad Logitech Poweplay
    OS Windows 10 Home x64
    Nov 2018
    114
    Turned on in BIOS, any messages in Aura?
    New ROGer Array
    Aug 2019
    3
    Quote Originally Posted by Enderwiggin03 View Post
    Thank you for your answer, I have no message in Aura, and what you mean turn on BIOS?
    ROG Guru: Yellow Belt Array Guitarmageddon888 PC Specs
    MotherboardMaximus x code bios1704
    Memory (part number)8700k 5.1/4.9avx
    Graphics Card #1MSI 2080 gaming trio
    MonitorHP Omen 27"
    Storage #1Samsung 970 m.2
    Storage #2Samsung 860 evo
    CPU CoolerH150i
    CaseLian li pc011
    Power SupplyEvga supernova g3 850w
    Keyboard Corsair k70
    OS Windows 10
    Nov 2018
    12
    194
    I think he meant ensure you have LEDs enabled in the bios settings itself? Have you flashed to a more recent bios by chance? I have been chasing some LED issues recently and Im fairly certain that AURA writes something to the motherboard itself. Something that I consider could be at least "wiped" by a new bios flash. Not sure if that would help here but maybe worth a shot.
    New ROGer Array
    Aug 2019
    3
    Quote Originally Posted by Guitarmageddon888 View Post
    Hi bud, I did a flash after the LED went off, and still nothing happen, I turn on everything in BIOS. This board and the LED control is pretty annoying. Any advise?
    ROG Member Array PLaYCUDA PC Specs
    PLaYCUDA PC Specs
    MotherboardAsus Rog-Strix Z370-E Gaming
    ProcessorIntel Core I7 8700K 3.7ghz
    Memory (part number)GSkıll (16GB) Trident-Z DDR4 3600MHz RGBLED
    Graphics Card #1Asus Rog-Strix GeForce GTX 1080
    MonitorSamsung S24D330H 1ms
    Storage #1Samsung 250GB 960 EVO M.2 Sata X2
    Storage #2Seagate Firecuda 2TB+8GB SSD Gaming SSHD
    CPU CoolerCorsair H100i-v2
    CaseDark Black R30
    Power SupplyCorsair RM750x 80-Plus Gold
    Keyboard Logitech G910 Orion Spectrum
    Mouse Logitech G502 RGB Proteus Spectrum
    Headset Logitech G633 RGB Artemis Spectrum
    Mouse Pad Steelseries QCK Prism XL RGB
    Headset/Speakers Logitech Z2300
    OS Windows 10 Pro
    Network RouterAsus VDSL/DSL-N16
    Accessory #1 Xbox One Elite Controller
    Apr 2018
