Results 1 to 4 of 4
    New ROGer Array
    Sep 2019
    2
    Where would I buy an FX504GM replacement fan?
    Here is my laptop model: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Over the past couple of weeks, the left fan has started making a grinding noise whenever it is not operating at max speed. I called support and was asked to ship the laptop to texas (it is under warranty), which is not something I'm interested in doing. I asked the rep about what company manufactures the fan or whether they could send me the part, which was not an option. The rep told me that Asus manufactures the fans which I am fairly certain isnt true.
    I could really use some software to monitor fan RPM and also control it (my previous laptop, an acer predator, had built in software that could do this).
    I was also wondering if anyone could tell me where I can purchase a compatible fan replacement so I can just replace it myself.
    Thanks!
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    17
    1,682
    can you check if these one can do? CHECK very very carefully
    https://www.aliexpress.com/i/32844394179.html
    But! warranty is most preferred way.
    Learn, Play Enjoy!
    New ROGer Array
    Sep 2019
    2
    Hmm. Those do look like the fans inside my laptop, but the shipping date is more than 2 weeks away. Is there another source like newegg I could use?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,472
    I would check Ebay. There may be a US based seller that could get it to you faster.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
