Results 1 to 8 of 8
    ROG Guru: White Belt Array
    Jul 2013
    11
    118
    Can i connect a USB c monitor to a GL504GW?
    i was looking around and i dont think you can but just making sure.
    Jul 2013
    11
    118
    well i just bought one. i will keep you guys updated. it gets here in a week
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,473
    Yeah, don't know, but I don't see why not. Hope it works out for you.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array crispi420's Avatar
    Mar 2017
    31
    19
    tell us if it worked. good luck
    Jul 2013
    11
    118
    As i suspected the usb-c on the GL504gw doesn't have video output. Anyways the monitor i ordered is hdmi and usb-c input (i tried the usb-c input with my Galaxy note and it worked)
    Handy "little" monitor 15.6 inches
    PS- in the picture is very reflective because i have not removed the plastic from the screen, it is matte.
    Jul 2013
    11
    118
  7. #7
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    301
    7,473
    Make sure you try turning down the brightness and/or plugging in dedicated power on the right side of the panel with USB-C. This reviewer found that the Lepow would cut out when only running off USB-C when the brightness is turned up.
    https://www.youtube.com/watch?v=J2Yo55Ur__Y
  8. #8
    Jul 2013
    11
    118
    i saw that video that is where i got the info to buy mine but i think the problem of the screen cutting is when he was pulling power from the phone itself.
