Dual RTX 2080ti OC stuck at Power target status 400% and GPU clock at 300MHz.
NightIIIX
Dual RTX 2080ti OC stuck at Power target status 400% and GPU clock at 300MHz. (as in picture, just after reboot) Is this card dead?
It seems to randomly recover sometimes but now its stuck and when it recovers it seems to work for maximum of one hour or so before its stuck again. (This even with default settings). Games work exactly as one would expect with 300MHz clock frequency(horrible framerates).
Tried: Reinstall drivers, Reboots helped initially but not anymore, GPU Z changing any setting does not make any difference, Afterburner shows same results, NVidia power setting seems to make no difference, 1080ti worked flawlessly just before this card.
STRIX Z270H Gaming + Intel i5 7600K + G.Skill 3200MHz 16GB
EVGA 850W SuperNOVA 850 P2, 80 Plus Platinum
VBIOS: 90.02.0b.00.AS02
82519
edrickjk
I would suggest to desinstal gpu tweak it probably will fix your issue.
MrAgapiGC
i see that also. i think is more a windows issue than a app or gpu. i detect these on afterburner and gputweek. the boost is cause the gpu is doing something.
Learn, Play Enjoy!
