Results 1 to 1 of 1
Thread: STRIX 2070 super leaking oil?
10-15-2019 06:04 AM #1
- Join Date
- Sep 2019
- Reputation
- 10
- Posts
- 5
Hi, I recently bought a new strix 2070 super.
I immediately noticed that at startup the fans make a really loud noise, but I assumed it was normal.
Then, after less than a week, I noticed some liquid droplets at the GPU's height on the inside of my side panel. So I opened it to investigate, and noticed that one of the fans was literally leaking oil, spraying it on my components when spinning.
I don't think that's normal, what should I do?
