Results 1 to 1 of 1
    ROG Enthusiast Array AliAPCMR PC Specs
    AliAPCMR PC Specs
    MotherboardZ390 E
    Processori5 9600k
    Memory (part number)Corsair RGB Vengeance (Corsair CMR16GX4M2A2666C16)
    Graphics Card #1GTX 1070 EVGA FTW
    Sound CardAsus SupremeFX
    MonitorSamsung 1080p 40inch 3D Tv
    Storage #1Samsung Evo 500gb SSD
    Storage #23TB & 2TB &500GB HDD
    CPU CoolerNoctua U12S
    CaseNZXT Noctis 450
    Power Supply850 wats EVGA SUPERNOVA
    Keyboard Corsair Raptor K30
    Mouse Logitec M305
    Headset Creative Sound Blasters Rage V2 Wireless (RGB)
    OS Windows 10 (Latest Update)
    Accessory #1 NZXT GRID V2
    Accessory #2 NZXT HUE PLUS
    AliAPCMR's Avatar
    Sep 2017
    51
    Asus Aura 1.07.71 problem with game effects mode
    I had a issue to where i had to re install this software from scratch i.e remove all instances of aura using aura cleaner and using ccleaner and the re installing aura and this solves everthing and aura works as it should. But soon as i shutdown the pc and turn it back on aura has a issue with game effects it stops working. I dont understand why i have to keep uninstalling and re installing to get this working and soon as i shut the pc down and turn it back on the feature stops working. At first i was like this is awesome playing black ops 4 going in the water the leds change blue then getting killed changing red and it looked awesome. Then i turned my pc off and turned it back on game effects mode stops working the leds dont change when i die and after dieing a few times the colour freezes on orange on the ram and the mobo led freezes on red, quiting the game just sticks the leds on orange. Why is this happing? It works after re installing everything but shuting down the pc causes aura game effects to break.
Tags for this Thread
