Results 1 to 9 of 9
10-19-2019 04:05 PM #1
- Join Date
- Nov 2018
- Reputation
- 10
- Posts
- 3
GL703GM only ~8 months old very suddenly running extremely slowly
Recently I booted up my laptop and some windows popup said how it had to uninstall some update to boot up. This was where my extremely fast laptop turned to garbage. Now regular browsing sometimes gets laggy and I also struggle to get 30 fps in literally any game, and im out of ideas. I have tried: Reinstalling Windows, Changing numerous power settings, Changed many Nvidia graphics settings, Uninstalled some windows updates (before reinstalling windows), Reset my BIOS settings to default, Reinstalling the slowly running programs, and I tried installing older Nvidia drivers. I have also tried moving the games from my HDD to my SSD, but that had no effect.
Before whatever happened, I never had any problems getting over 120 fps on Fortnite at max settings, as well as got over 120 fps on Battlefield 4 on max settings with a high render scale. Also it does not appear there is any issue interally on the laptop. Now I am struggling to get 30 frames in Fortnite and only get 10 fps in BF4 with the same settings.
10-19-2019 10:27 PM #2
hi man when u said reinstalled windows, u did a clean ssd format?
once i had my laptop running slow with high temperatures and cpu/gpu usage, then i saw a crypto mining program runing in backgroud. try to scan ur computer with malwarebytes and see if theres those kind of app runnig...
good luck
10-20-2019 02:23 AM #3
You're probably running on the iGPU.
10-21-2019 09:51 PM #4
- Join Date
- Nov 2018
- Reputation
- 10
- Posts
- 3
10-21-2019 09:53 PM #5
- Join Date
- Nov 2018
- Reputation
- 10
- Posts
- 3
10-22-2019 01:03 AM #6
- Join Date
- Jul 2013
- Reputation
- 11
- Posts
- 134
10-23-2019 07:34 PM #7
- Join Date
- Feb 2019
- Reputation
- 28
- Posts
- 53
No issue in my GL703GM. My motherboard has been changed after 3 months because my laptops has been dead in 3 months. Now is very silent.
Fast boot with Samsung 970 PRO M2 Nvme and 32 GB RAM HyperX 2666 MHz CL15
10-23-2019 11:37 PM #8
- Join Date
- Oct 2019
- Reputation
- 10
- Posts
- 40
gl703gm is not utilizing integrated gpu. It is using only gtx 1060. this is basic knowledge. please dont advise in something that you don't know anything about.
10-24-2019 01:30 AM #9
RedSector73 PC Specs Laptop (Model) FA506IU-AL130T x 2 Motherboard ROG CROSSHAIR VIII HERO (WI-FI) Processor AMD Ryzen 9 3900X 12-Core Processor Memory (part number) 4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die Graphics Card #1 Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC) Sound Card Arctis DAC Monitor Asus ROG Swift PG348Q Storage #1 ADATA SX8200PNP 1TB Storage #2 2 x Samsung SSD 840 EVO 250GB CPU Cooler Coolermaster Liquid Pro Master 360 Case EVGA DG-87 Gunmetal Grey Gaming Case Power Supply EVGA SuperNOVA G2 750W Gold Power Keyboard Corsair K95 RGB Platinum Mouse Corsair Gaming Sabre RGB Gaming Mouse Headset ARCTIS Pro Wireless Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large OS Windows 10 64bit Pro Network Router RT-AC87U
- Join Date
- Apr 2018
- Reputation
- 43
- Posts
- 877
I would check out your OS is good by this:-
POWERSHELL:-
run as admin [powershell] (type into search bar, when you see it pop up, right click on it and run as admin)
sfc /scannnow
wait till complete
now run (still in powershell)
Dism /Online /Cleanup-Image /RestoreHealth
wait till complete
if either found and fix integrity errors or corruptions, reboot and then repeat both steps again. Should this become a loop then reset of windows or fresh install are the only options.
Next, I would try
snappy driver installer, download the light vesrion
https://sdi-tool.org/download/
This program is best at getting optimal drivers for your system.
Video - how to use the program
This will help eliminate software/drivers as the issue.
Lastly, I would try DDU https://www.wagnardsoft.com/ This is used to completely uninstall you nvidia driver and best done in windows safemode. I would then reinstall the latest or your choice and use custom and click clean install checkbox.
This is bit of process but the steps I would take
Hope you find this of help.
