What cooler for 9900K @5.0 GHz OC?
Alexauwa
Hey guys,
I was looking into the Noctura Noctua NH-D15S for cooling but are not sure if it is the best option. What do you think?
Thanks,
Alex
4 REPLIES 4
Falkentyne
Level 12
Alexauwa wrote:
Hey guys,
Thanks,
Alex
D15S with dual 140mm fans (or Noctura 3000 RPM industrial fans) is the best for air cooling. Of course you can do better but that's in AIO or custom loop water cooling.
Thanks! I'd go for AIO but simply didnt find any aio system that would outperform the Noctura. Is there any one u know? No custome on though as I dont know how to build it.
HisEvilness
The ROG Ryujin 240 or 360 but I also used the H150i Pro from Corsair they work like clockwork.
im using Corsair Hydro Series H150i Pro RGB 360mm i've OC mine @5.0ghz with max temp 80-85 full load.
