Results 1 to 8 of 8
    ROG Member Array
    Oct 2017
    14
    Armoury Crate and ROG Rampage VI Extreme no ADD Header
    As the title indicates, fully updated Armoury Crate works for aura sync no problem, except it doesn't see or control the ADD header on the motherboard. Worked fine before in AURA Sync 1.07.57 which was installed before I put Armoury Crate in. Sees motherboard, RAM, RGB Header 1 and 2, keyboard, monitors, mouse, mousepad, but not the ADD header.
    ROG Guru: Orange Belt Array
    Apr 2019
    19
    267
    Quote Originally Posted by marcmicalizzi View Post
    can you perform a cmos clear?
    ROG Member Array
    Oct 2017
    14
    Quote Originally Posted by Re@per View Post
    I'll give that a try tonight and do a BIOS update at the same time. It takes a little while to input all the overclock and raid settings in the bios so I'll need to find a bit of time I don't need my computer for
    ROG Member Array
    Oct 2017
    14
    Lovely. After a BIOS update and cmos clear NO devices show up in armoury crate now. Reinstalling Armoury Crate did not fix it either.
    Apr 2019
    19
    267
    Armoury Crate Service and rog live Service Running? It can take some hours till Crate will get initiated don’t know why. After 2!hours Crate showed all stuff for me
    ROG Member Array
    Oct 2017
    14
    Don't see an Armoury Crate service, but AsusROGLSLService Download ROGLSLoader, ASUS Com Service, ASUS System Control Service, AsusFanControlService, and ROG Live Service are all running. Still no devices in Armoury Crate a full day later though.
  7. #7
    Apr 2019
    19
    267
    well you need the Armoury Crate Service, can you start the web Armoury Crate installer as admin again*
  8. #8
    ROG Guru: Yellow Belt Array Dimitrios1971 PC Specs
    Laptop (Model)GX700VO 1TB SSD + 64GB RAM
    MotherboardASUS ROG ZENITH EXTREME ALPHA
    ProcessorAMD Ryzen Threadripper 2950X
    Memory (part number)F4-4000C18Q2-64TZR (3333MHz)
    Graphics Card #1ROG Strix GeForce® GTX 1080 Ti OC-Edition
    MonitorROG Swift PG348Q Gaming
    Storage #13 x Samsung SSD NVMe 960 PRO 1TB Raid0
    Storage #24 x Samsung SSD NVMe 970 PRO 1TB Raid0
    CPU CoolerCOOLER MASTER MasterLiquid ML360 RGB TR4 Edition
    CaseROG Strix Helios
    Power SupplyASUS ROG THOR 1200P
    Keyboard ROG Strix Flare RGB
    Mouse 2 X ROG Chakram
    Headset ROG Throne Qi
    Mouse Pad ROG Balteus Qi RGB & ROG Sheath
    Headset/Speakers 2 X ROG Strix Go 2.4
    OS Win10_x64
    Network RouterFRITZ!Box 6660 Cable
    Accessory #1 BW-16D1H-U PRO
    Accessory #2 Asustor AS6404T
    Accessory #3 HYPER M.2 X16 CARD V2
    Dimitrios1971's Avatar
    Apr 2015
    65
    128
    new ROGLSLService_2.0.3.0_NEW_30.10.2019 is aut
    Version - 2019/10/302.38 MBytes
    https://dlcdnets.asus.com/pub/ASUS/m...LSLService.zip
    E15698_Armoury_Crate_FAQ_QSG_WEB
    https://docdro.id/akoFBgO
    Armoury Crate Installer
    Note: Please uninstall your existing AURA software before installing Armoury Crate.
    *The most recent versions of the Aura software can still be downloaded from the aura sync website: https://www.asus.com/campaign/aura/global/download.html
