Results 1 to 4 of 4
    ROG Member Array fliersrr PC Specs
    fliersrr PC Specs
    MotherboardMaximus IX Hero
    ProcessorIntel Core i7-7700K Kaby Lake Quad-Core 4.2 GHz
    Memory (part number)F4-3600C16Q-32GTRS Royal RGB
    Graphics Card #1Nvida GeForce GTX1070 GDDR5 8GB Founders Edition
    MonitorPlanar PX2710MV Qty 3
    Storage #1SAMSUNG 960 EVO M.2 NVMe 250GB Qty 2 RAID 0
    Storage #2SAMSUNG 840 Pro Series SSD Qty 2 RAid 0
    CPU CoolerXSPC X4, Phanteks CPU block, Hardline
    CaseThermaltake P5
    Power SupplyCorsair HX750
    Keyboard Corsair RGB Strafe
    Mouse M65 RGB Elite
    Mouse Pad Corsair RGB MM800
    Headset/Speakers Bose 2.0
    OS Windows 10 64bit
    Network RouterNetgear R7000
    Accessory #1 ASUS USB 3.0 External 12X Blu-Ray Re-writer Model BW-16D1X-U
    fliersrr's Avatar
    Aug 2017
    8
    Question RGB DDR4 memory for Maximus IX Hero Z270 motherboard Question
    How can I tell if RGB RAM DDR4 will work with my motherboard? The QVL is so old. (Feb 2017) Is there a way to tell? What makes RAM compatible?
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,832
    Quote Originally Posted by fliersrr View Post
    Hello, the QVL is old as the motherboard is fairly old, too. Please check the memory vendor QVL for compatibility. Or choose a kit at or below 3600Mhz to ensure the best chance of plug and play compatibility at XMP.
    ROG Guru: Yellow Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)SamSung
    MotherboardROG Maximus IX Extreme
    ProcessorI7-7700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #2ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    MonitorSAMSUNG S22D300HY (2 ea)
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK Kit L360
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard Cerberus
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Win 10 Pro 1909
    Network RouterGeneric
    Accessory #1 ROG Aura Terminal
    Accessory #2 ROG 10GB Express
    Jan 2016
    157
    QVL is so old
    Google “G-Skill RAM Configurator” and check for F4-4000C18Q-32GTZSW (not compatible).
    The ASUS QVL for the IX Extreme list G-Skill F4-360017CQ-16GVK as compatible, where as G-Skill QVL list does not list the IX Extreme compatible with F4-360017CQ-16GVK.
    So, on a cold boot first number Q-Code 15 (count: one thousand, two one thousand, three one thousand), Q-Code CC or Q-Code 49, always follows.
    And on a cold boot first number Q-Code 25 and stops on Q-Code 32 (count: one thousand, two one thousand, three one thousand), Q-Code 55 follows. Or if it stops on Q-code 32 for a count of one thousand, two one thousand the computer boots fine.
    No problems with G-Skill F4-360017CQ-16GVK on VIII Gene or VIII Extreme Assembly. Works fine on VIII Formula if using BIOS 2202 or lower. Hit or miss for any BIOS above 2202.
    fliersrr PC Specs
    CaseThermaltake P5
    Mouse M65 RGB Elite
    OS Windows 10 64bit
    fliersrr's Avatar
    Aug 2017
    8
    Thank you both for your replies. I have reached out to ASUS for help as I wanted to update my memory that I have been using for a few years now to RGB. ASUS submitted to engineering dept to update the QVL but that may take a few months. He did also say to see if the RAM manufacturer offers a QVL. (like you said)
    As much as I want the Corsair Dominator RGB memory, I may not be able to get it as I can not find any answers on their products. G.Skill has their own QVL and have a lot of choices for RGB RAM for my motherboard. I reached out to Corsair for help and was told to go to ASUS for help. ? On Corsair this is the second time I have reach out to Corsair for help over the years, and both time received non-helpful help. ASUS on the other hand actually phone called me from California. Then two follow up emails. I do like the Corsair products and have a lot of them, but have to say support is like contacting kids.
    On another note in researching RAM people have also said you can use any DDR4 as long as you are willing to do the work to set the timings up yourself. They did explain you need matching RAM etc. which I already knew. The "SPD" profiles in the RAM chip may not work and you have to set the timings up yourself.
    I really want that Corsair Dominator RGB RAM, but just not sure what to do.
    Thanks again for your replies.
Tags for this Thread
