Results 1 to 3 of 3
    ROG Guru: White Belt Array wolfy PC Specs
    wolfy PC Specs
    Laptop (Model)Acer swift 3
    MotherboardROG Maximus XI Formula
    ProcessorI9 9900K
    Memory (part number)4x 4 GB kingston hype X DDR4 @3000mhz
    Graphics Card #1Auros 2080 super 8GB
    Monitordell 34" curved+23"ASUS +21" iiyama touch
    Storage #1250 GB M.2 NVMe Samsung+1 500gb M.2
    Storage #22 x 500 ssd +1 x 250GB ssd ocz
    CPU CoolerEKWB watercooling
    CasePhanteks enthoo Primo
    Power SupplyCorsair 1000W
    Keyboard Razor Black widow Chroma
    Mouse Razor Mamba Chroma
    Headset/Speakers Razor /Logitech
    OS Win 10 Pro
    Jun 2011
    12
    101
    Maximus XI formula wifi
    Hi i have owned a fair few formula and for the last 2 years used it with my I7 7700k and never had any problems
    i know have the latest version with a I9 9900k but the Wi-Fi is really bad compared to the last one the new one uses Intel i get between 250 and 500 Mbps and its not constant, my old board never went below 866Mbps is it the new antenna thats bad or just the INEL Wi-FI
    ROG MAXIMUS XI FORMULA
    CPU: Intel 9900K @4.7 ghz
    2 x Corsair Vengeance RGB PRO DDR4-3200
    C16 BK DC - 16GB
    1 x Aurous 2080Super 8GB
    1x 500GB Samsung 970 M.2 NVMe
    1x 500GB AData 8200pro M.2NVMe
    2 X 500 GB OCZ SSD
    1000w PSU from corsair
    Tower Phanteks Enthoo Primo
    1 x dell 34" curved + 1 x 24"
    CPU and Motherboard.
    water cooled by EKWB
    ROG Guru: Yellow Belt Array Ch3vr0n PC Specs
    Ch3vr0n PC Specs
    MotherboardAsus Maximus XI Formula
    ProcessorCore i9 9900k @ 4.7GHZ (XMP)
    Memory (part number)CMT32GX4M4Z3200C16
    Graphics Card #1Asus Strix GTX 1080 A8G
    Sound Cardon board
    MonitorASUS VG278HR & ASUS VK278Q
    Storage #1Samsung 970 Evo 1TB (Boot) & 970 EVO 2TB (Scratch)
    Storage #23X HGST 10TB, 1x HGST 4TB
    CPU CoolerScythe Mugen 5 PCGH
    CaseCooler Master Cosmos II
    Power SupplyCorsair AX860i
    Keyboard Corsair k95 RGB Platinum
    Mouse Corsair M65Pro RGB
    Headset Corsair Voide Wireless SE
    Mouse Pad Corsair MM300 + Corsair MM800 Polaris (EU)
    Headset/Speakers Logitech Z-906
    OS Windows 10 Pro x64
    Network RouterNetgear XR500
    Accessory #1 Xbox One Elite Wireless Controller
    Accessory #2 2X Corsair LL140, 4x Corsair LL120
    Accessory #3 1x Corsair LED RGB Pro expansion kit, 2x LS100 RGB kit + 450mm expansion kit
    Ch3vr0n's Avatar
    Nov 2012
    38
    237
    zero problems here using that same board and CPU. but then again i'm lucky to get 200Mbps ISP wise. it's not just the board's wifi that matters, are you using the antennae that came with it, is your router up-to-snuff? How's your signal strength...
    wolfy PC Specs
    ProcessorI9 9900K
    OS Win 10 Pro
    Jun 2011
    12
    101
    same router, same set up ,same place as my last build nothings changed apart from the new mainboard and antenna that came with it
    C16 BK DC - 16GB
    2 X 500 GB OCZ SSD
