Results 1 to 2 of 2
    ROG Guru: Orange Belt Array JimmyH PC Specs
    JimmyH PC Specs
    MotherboardROG Strix Z370-E
    Processor8700K
    Memory (part number)CMK32GX4M4B3200C16
    Graphics Card #1ASUS STRIX GTX 1080
    MonitorBenq 27" x 2
    Storage #1Samsung 970 EVO
    CPU CoolerThermaltake Floe Ring 360
    CaseThermaltake View 71
    Power SupplyCorsair RM 850x
    Keyboard Strix
    Mouse ROG Pugio
    Headset Logitech933
    OS Windows 10 Pro
    JimmyH's Avatar
    Nov 2012
    20
    294
    RGB LED's MIssing - STRIX 1080 Gaming
    Has anyone else had an issue where half the LED's on the GPU are missing or dimmed. Please see attached picture. This happened quite a few weeks ago, but I thought it was just the angle of the light in the room, added to that I haven't been on my PC for a while.
    Things I have tried:
    Uninstall/Re-installed AURA
    Uninstall/Re-installed Armory
    Updated to latest drivers.
    Have unpluged PSU and reconnected, same with PCIE slot.
    The first two LED's are dark, the middle ones dim, and the end two lit.
    I have also tried different settings on AURA.
    Help please
    CPU i7 8700K: MB: ROG Strix Z370-E Corsair Vengeance 3000 (4x8GB) : GTX-1080: Samsung 970 EVO, 2 x Kingston Hyper X
    500GB Velocerapter, PSU Corsair RM 850x
    Case Thermaltake View 71: Cooling Thermaltake Floe Riing 360 mm
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    27
    1,769
    Quote Originally Posted by MrAgapiGC View Post
    That is not issues with aura. That is the plastic tube being crystallize. There are only 2 led diode there. You need to replace those. Is easy there is a post somewhere here im order to check how is done and what size (diameter) but is easy.
    here is the link
    https://rog.asus.com/forum/showthrea...RGB-LEDs/page5
    Learn, Play Enjoy!
