Results 1 to 8 of 8
    ROG Member Array taz00 PC Specs
    taz00 PC Specs
    MotherboardROG Crosshair VIII Hero (WI-FI)
    ProcessorAMD Ryzen 9 3900X
    Memory (part number)F4-3600C16-8GTZN
    Graphics Card #1ROG-POSEIDON-GTX1080TI-P11G-GAMING
    MonitorROG PG278QR
    Storage #1Samsung SSD 970 EVO 2TB
    CPU CoolerEK-Velocity RGB - AMD Full Nickel
    CaseFractal Design Define R5
    Power SupplyCorsair HX1000i
    Keyboard Corsair K95
    Mouse Logitech MX518
    Headset Steelseries Arctis Pro Wireless
    OS Windows 10
    Accessory #1 Thermal Grizzly Conductonaut Liquid Metal Gpu+Cpu
    Accessory #2 Custom Water Loop
    Oct 2019
    6
    Crosshair Hero x570 custom waterloop, FanExpert cant control pump & fans properly
    tldr; I want to control fan and pump speed based on Water_IN sensor or both GPU + CPU temp, but that's not possible.
    I have a ROG Crosshair VIII Hero (WI-FI) with a 3900x, and a Asus 1080ti Poseidon Platinum. Cooled by a single loop 5 fan radiator and D5 pump, with temp sensor on the input. (see picture)
    https://www.asus.com/Motherboards/RO...I-FI/HelpDesk/
    https://www.asus.com/Graphics-Cards/...I-P11G-GAMING/
    According to the manual (see screenshot) you're supposed to connect radiator fans to the CPU and CPU_OPT fan ports.
    There's no option to change temp source on CPU fans (see screenshot), I guess that makes sense for most people, unless they want to hit thermal throttle all day.
    I could adjust my CPU fans for a more agressive curve, but idle a 3900x sits between 38c and 50c, and 100% loaded im at 70c. So my fans would be spinning up and down all day. But I just want them at max once water temp is 10c higher than normal, and not wake me up in the middle of the night because an update pushed the cpu temp up 5c.
    The option to select temperature source on the water pump is permanently greyed out (see screenshot), how do I enable it? I actually have no idea what temperature it even reads from, as its not displayed, could be anything really....
    Pump PWM works fine.
    Water In T Sensor works fine, but doing GPU heavy tasks the water temp can rise 12c+ without the cpu noticing, and fans + pump still run slow, because there's no way to react to it.
    So, do I disconnect radiator fans from CPU fan connectors and use the High Amp Fan connector to better control fans? (it has source option)
    Then I still can't control pump speed according to water temp... or any other temp.
    GPU overclock becomes unstable during gaming, because CPU isnt loaded, and fans and pump keep quiet so water temp keeps rising.
    Overall the motherboard has all the features to eliminate external water control systems (which i love), but software can't be configured for it.
    I'm looking forward to any suggestions.
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,252
    What bios are you using ?
    taz00 PC Specs
    MonitorROG PG278QR
    OS Windows 10
    Oct 2019
    6
    Quote Originally Posted by RedSector73 View Post
    Version 1001
    Should be the latest one, as of this moment.
    Apr 2018
    65
    1,252
    might want to try this BIOS in the below post and see if they have corrected it
    https://rog.asus.com/forum/showthrea...-BIOS-download
    taz00 PC Specs
    MonitorROG PG278QR
    OS Windows 10
    Oct 2019
    6
    Thanks for the link, didnt know there was "secret" bios releases :P Will check it out, but I don't think it will do anything in Ai-Suite to enable source selection.
    Reason for that is, I snooped around the fan control service exe and dll's, and found that they have fan info stored in :
    C:\Program Files (x86)\ASUS\AsusFanControlService\2.00.77\FanInfo.d ata
    using an efficient data storage protocol by google, called Protocol Buffer :
    https://developers.google.com/protoc...rs/docs/proto3
    By using https://github.com/protocolbuffers/p...10.1-win64.zip to create a C# class, which I then imported into the protocol buffer Csharp examples, I am now able to read the FanInfo.data (see attachment)
    I should also be able to Edit the configuration and unlock Source and Multisource for all fans. But thats gonna be for tomorrow.
    taz00 PC Specs
    MonitorROG PG278QR
    OS Windows 10
    Oct 2019
    6
    Well, that didnt work ¯\_(ツ)_/¯
    FanInfo.data gets overwritten when fan control service restarts
  7. #7
    New ROGer Array borob PC Specs
    borob PC Specs
    MotherboardCrosshair VIII Impact
    ProcessorRyzen 7 3800X
    Graphics Card #1Asus 1080 FE + EK FC1080
    MonitorLG 34UC89G
    Storage #11TB Toshiba XG3 NVMe
    Storage #22TB Toshiba XG5 NVMe
    CPU CoolerEK Velocity
    CaseSilverstone GD04B
    Keyboard Razer Blackwidow X Chroma
    Mouse Razer Mamba Tournament Chroma
    Headset Logitech G930
    OS Win10 / MacOS
    Network RouterCustom PfSense
    Feb 2020
    3
    Lightbulb 1302 bios
    I've had the same problem with fan control on my C8I, using multiple fans on the RAD headers + D5 pump and 3 temp sensors, but few day after opening a ticket with Asus, a new BIOS (1302) popped up on the support site and that's fixed my problem.
    Fan control works as expected now, including multiple source with temp sensors and step down-up.
    You have the same version available for your board as well, give it a go if you haven't done it yet.
  8. #8
    taz00 PC Specs
    MonitorROG PG278QR
    OS Windows 10
    Oct 2019
    6
    Asus actually pushed out an update to the AI suite shortly after i posted this, which solved my problems.
    Also got the 1302 update, will have a look and see if I have more options now ty
Tags for this Thread
