Results 1 to 5 of 5
    ROG Member Array
    Apr 2014
    Unhappy STRIX 5700 XT - Screw + Heatsink Mounting Problem
    So i guess some of you might have heard, there are some problems with quality control regarding this card.
    I am having the same issue, which causes my card to overheat and throttle like crazy, and on some occasions generate out of VRAM errors, namely in World of Warships and Ghost Recon Breakpoint.
    I refused to start unscrewing and changing screws on my own, in fear of losing warranty.
    Here is the problem explained https://www.reddit.com/r/Amd/comment...strix_5700_xt/
    One person on a hungarian forum, switched 2 sets of screws and was able to achieve good mounting pressure
    https://mobilarena.hu/dl/upc/2019-10...021_160845.jpg
    I have had a chat with support, who pointed me to the local service agency.
    I do not have another card to spare, and i would gladly fix the problem myself, and even told this in the ticket i sent to support.
    Just send me a good set of replacement screws and ill do it myself.
    I do not wish to send the card to RMA only to
    A. wait months for a reply
    B. get the card back, while they say everything is fine, when it is not
    Please advise, what the hell should i do?
    Should i just sell the card, and buy the generally claimed winner of the custom 5700 XT's, the Sapphire Nitro?
    Anyone else here having the same problem?
    New ROGer Array
    Dec 2019
    1
    Angry 5700 xt heatsink is loose
    I have the same problem. The heatsink is loose on the far end from the mounting flange. The screws are too long or they forgot to put washers in. Bump this thread so they can fix the issue and send the correct screws to customers!
    I was hitting 112 C die temp and 96 C edge temp while gaming at 1080p, 60 fps, ultra settings in GR Breakpoint. This was the first sign that something was very wrong. I saw your thread and the youtube video and found the exact same problem. If there is no thermal contact, then the heat won't get out. Very sad quality control ASUS. Make it right and send the correct fasteners!
    ROG Member Array
    Apr 2014
    Quote Originally Posted by DMutt37 View Post
    This is definetly the last time i bought an ASUS GPU. I have always sticked with Sapphire and ASUS, guess its just Sapphire now...
    ROG Junior Member Array scasn4 PC Specs
    scasn4 PC Specs
    Motherboardvii hero
    Processor2700x
    Memory (part number)32GB g-skills rgb 3200
    Graphics Card #1RX 5700 XT
    Storage #11tb crucial ssd
    Storage #22TB seagate 7200rpm
    CPU Coolerh150i
    Power Supplycx750
    scasn4's Avatar
    Feb 2015
    2
    I can confirm changing the screws has dropped my junction temps by 16-18oc and overall at full load by as much as 20oc and the card feels more solid now
    New ROGer Array
    Feb 2020
    1
    Report after screw exchange at ASUS repair center
    Short feedback for the ASUS repair center and what was done after the notice.
    Sent my RX 5700 XT to the czech repair center and it was back within 1 week. So this was really quick!
    The 4 screws at the GPU are shorter or much more tightened then before, as the springs between PCB and screw are much more compressed.
    GPU temp is now max. 78°C and hotspot max. 91°C at room temperature of 22°C. The GPU is 10-15°C cooler than before the 'repair'.
    Memory is still getting very hot (max 92°C, 1080P gaming AC Odyssey ultra, single display 60Hz), but as it matches the GDDR6 specs and other manufacturers also have this high temps, it's fine for me.
    Additional I had the fault at high temperatures at the VRMs resulting of the gap between heatsink and VRM.
    Repair report listed a defect fan at the VRM stage which was replaced...... At my PC all 3 fans are working quite perfect.
    They have replaced the grey thermal pad with a yellow one which seems to be a little bit thicker.
    BUT..... ASUS, really? The screws at the VRMs are still too long! I still have the gap heatsink/VRM....
    The GPU VRM temperatures at gaming are as high as befor the 'repair' (80-85°C).
    Using the universal solution of 2 pieces 1mm washers at the heatsink/VRM construct it is much cooler than before (max 74°C).
    I would say "half way gone, two screws left.... you can do that!"
Tags for this Thread
