TUFF x570 wifi- RAM SPEED 3200 oc issues
strixstrix
hey all, I have a new Tuff x570 wif mb, running:
G Skill 32GB (2X16G)F4-3200C16D-32GVK RipJaws V 3200MHz DDR4 RAM
seem to have some issues running at 3000mhz, stable at 2800 though, specifcally a cad program wouldn't run
any one else having issues ?
bios is 1201
5 REPLIES 5
RedSector73
Level 12
Let's check if it's configuring properly. First, make sure using slots 2 & 4 from the cpu, not 1 & 3.
When go into the bios, in advanced, you need to select/use DOCP profile for 3200 not manually select ram frequency to 3200 which causes poor timings. This will allow it load the memory profile, the same Intel XMP does. If your experience is from Intel system and you selected ram frequency without using XMP the same thing would happen.
Example:-
Also make sure up to date on the bios, ASUS AGESA 1.0.0.4 BIOS was released today for most if not all boards applicable.
If your done all this and test and still have an issue with your ram. post back.
Hope you find this of help.
ASUS has released another BIOS update for its X570 boards that fixes the memory and wake-from-sleep issue people were having. Affects the X570 TUF, Prime and ROG series of boards.
uglykidmoe
have the same issue. tuf gaming x570 plus with wifi - bios 1405 - r7 3700x - corsair 2x16 vengence rbg pro ddr4 3200 16 18 18 18 36 1.35v (CMW32GX4M2C3200C). build is brand new, boots @ 2133 will boot at 2800, but no higher. any thoughts? : )
sabertooth z77 - corsair carbide 540 air - win 8.1 - i7 3770k - corsair H100i - crucial M4 256g ssd - wd raptor 600g x2 raid 0 - corsair vengence 32g - gigabyte gtx 780 ti oc x2 - liteon iHSb212 bluray - sound blaster zxr w/5.1 klipsch pro media - antec hcp platinum 1350w - corsair vengence m70 keyboard - corsair vengence m65 mouse - asus pb278q 27" 2560x1440@85hz
It boots fine on my set up. Ryzen 5 3600, X570 TUF Wifi and 3200 TForce Delta TUF Edition
uglykidmoe
happy for ya
