Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    ROG Enthusiast Array
    Sep 2014
    26
    Encore vs Omega: Which is better?
    I have a delidded 9990XE (the auction chip) which pulls over 600W itself when all cores are at 5.1ghz.
    I have a faulty Omega and it's been approved for a refund.
    Im torn on whether to get another Omega or go for the Encore.
    The Encore is $50 more expensive which is nothing when spending over 1k on a motherboard (Australia).
    Is one board better than the other? Does one have better VRM components?
    I thought the Encore was supposed to be a step down from the Omega, but it's more expensive.
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    127
    1,893
    Hello,
    The Encore is the better board, hence why it's priced above.
    I have linked you to the product comparison tool.
    https://www.asus.com/uk/Product-Comp...TSRcn68Lwd&b=2
    Sep 2014
    26
    Thanks for the response.
    The Omega is list as having - IR3555 PoweIRstage® while the Encore does not have this listed as a feature. Would this not imply the Omega has higher quality VRM solution?
    ROG Member Array MJB09SRT8 PC Specs
    MJB09SRT8 PC Specs
    MotherboardASUS Rampage VI Extreme Omega/Apex soon to be Encore
    Processor9940x & 7940x
    Memory (part number)gskill F4-3200C14Q-32GTZSW
    Graphics Card #1Titan X (pascal)
    Graphics Card #2Titan X (pascal)
    MonitorASUS Rog PG278Q
    Storage #11tb Samsung 970 pro
    Storage #21tb Samsung 960 Pro
    CPU CoolerEK Supremacy evo full copper
    CaseCaselabs STH10
    Power SupplyCorsair AX1600I
    Keyboard Razor Blackwidow X Ulitmate
    Mouse Razor DeathAdder Elite
    Mouse Pad Razor Manticor
    Headset/Speakers LG Z625
    OS windows 10 Pro
    Network RouterNetgear 6300
    Sep 2015
    5
    The Encore has Infineon TDA21472 which are better than the IR3555.
    Montrose
    New ROGer Array
    Feb 2019
    15
    69
    Encore has a much better power solution. Next gen power solution and better components according to ASUS: https://www.asus.com/us/Motherboards...xtreme-Encore/
    Apr 2017
    11
    52
    But what i missing on the Encore is a U2 Port, so in this Point i choose the Omega for me
  7. #7
    New ROGer Array
    Feb 2019
    15
    69
    Quote Originally Posted by einsindrei View Post
    you can use an U.2 to m.2 cable to connect a U.2 drive to a M.2 port. they are electrically compatible. Just a passive cable will suffice. I have several u.2 drives connected to m.2 on the Ramapage 6 Extreme that working perfectly fine for soon 2 years. You can even buy u.2 drives with this m.2 to u.2 cable included, e.g. intel sell 900P like that that retail. So in other words, no problem. If you really are set on using u.2 to u.2 connection (not necessary but lets say you want) then you can easily buy a u.2 PICe card with 2 ports - problem solved. However, the weaker power delivery system of the omega can not be fixed that easily.
    Power delivery is key to successful solid over clock with manageable temperatures. trust me on that: given my experience with my 7980XE on the original Rampage 6 Extreme I can say that you are very dependent on a robust power delivery system with very good cooling to get the max out of your core i9 cpu. I am looing forward to see what Encore can do. Maybe a 5GHz on all 18 cores is going to be the new standard OC no problem with the 10980 XE and a standard off the shelf 280mm CLC on the encore - we'll see.
  8. #8
    Apr 2017
    11
    52
    The Encore is nice, sure. BUt i was getting a 9980xe + Rampage Omega for 1000€, so i think this was a good Deal
  9. #9
    New ROGer Array
    Feb 2019
    22
    That was for sure a good deal for that combo. I have been using an Omega and loved the board overclocking ram and the cpu was a breeze, i now have the Encore and its a very unstable board for me right now, overclocking the cpu is easy but the ram seems to be a nightmare so far, i see several people in the forum having issues with the ram overclocking and even setting the XMP profile isn't working in most cases so far that i have seen. I even bought some 3866mhz ram thats on the QVL list for the Encore and cant it to work over 3400mhz.
  10. #10
    ROG Guru: Orange Belt Array vmanuelgm's Avatar
    Sep 2013
    32
    325
    3866 kit is not a good choice for quad channel... And yeah, u say it's listed in the QVL, but still not a good choice.
    The best kit for Omega in terms of OC is the 3600C16 non rgb wich also is relatively cheap.
    Omega, 10980xe, G.Skill 3600, 2080Ti, SM951 256, 970 PRO, 860 EVO
    Intel 750, WD SN750 Black, 840 Pro, 2xSkyhawk 4TB, 7200.14, 207EBK
    EVGA T2 1600, Silverstone TJ11, Custom LC. @Acer Predator x34
