delete
Mreksoll
delete
MrAgapiGC
Mreksoll wrote:
How to turn on livedash panel at omega board ? It's not work from unboxing , i try update uefi , try install livedash software but its balck and notting not display
check if you board have access in bios for Armory Crate
BUT! if the panel is dark on first start up. you need to check that with asus
Learn, Play Enjoy!
livedash was not connected to motherboard :confused: , i put my nvme ssd to dimm , and not touch metal plate near pci-e slots , when i disassembled that metal plate , I found not connector livedash , i connect it and livedash start work .
it’s good that I checked and did not make RMA ,
i could lose a month from such a small thing 😞
