Results 1 to 4 of 4
    New ROGer Array drunkencookie PC Specs
    MotherboardROG Strix x570 Gaming-f
    ProcessorRyzen 3700x
    Memory (part number)Corsair Vengeance LPX 3600 Mhz
    Graphics Card #1Sapphire RX5700XT Pulse
    MonitorBENQ EX3501R
    Storage #1Intenso 256 GB SSD
    Storage #2Crucial CT1000MX
    CPU Coolerbequiet! Dark Rock TF
    Casebequiet! Dark Base Pro 900 rev.2
    Power SupplyCorsair RM750i
    Keyboard Logitech G910 Orion Spectrum
    Mouse Logitech G903 Lightspeed
    Mouse Pad Logitech Powerplay
    OS Win 10 Pro x64
    drunkencookie's Avatar
    Nov 2019
    2
    X570 Gaming-f D.O.C.P. issues, Corsair Vengeance LPX 3600
    Hello,
    I've got a problem running the D.O.C.P. settings of my RAM.
    When I set the Profile everythin works just fine, no problems occured while running AIDA64 stresstest (about 2 hours). When I shut down my computer and turn it on again it won't boot. The DRAM LED is lit, no picture occures on the monitor, only thing that helps is a CMOS reset. When i restart the computer while running the D.O.C.P. profile everythin is just fine as well, no problems, no DRAM LED, normal booting.
    I don't want to use the CMOS reset, everytime I shut down the computer, but I really want to run it with the RAM on 3600Mhz, because I've got a much better performance while gaming.
    The D.O.C.P. profile is:
    clock: 3597Mhz
    latency: 18-22-22-42
    voltage: 1,35V
    Technical Data on the Corsair website says:
    clock 3600Mhz
    latency: 18-19-19-39
    voltage: 1,35V
    My hardware:
    Rog Strix X570 Gaming-f
    Corsair Vengeance LPX 3600 Mhz 16GB (2x8GB) C18
    AMD Ryzen 7 3700x
    Corsair RM750i
    When everything is set to Auto the RAM runs on 2666Mhz with 1,2V and I've got no problem while booting (except I had to activate CSM, otherwise I can't boot from any device connected and get stuck in the UEFI?!).
    My MoBo has BIOS version 0807 and I already thought about updating it, but I read a lot about problems with BIOS updates on X570 boards.
    Also had one myself with a MSI X570 Pro Carbon Gaming. After the BIOS Update nothing booted either and the CPU controll LED was lit, flashing to the old BIOS version with the BIOS flashback button didn't worked as well. Because of this I'm a little bit uncertain regarding a BIOS update.
    Has anyone experienced similar problems? Would it help to set the clock and latency manually (propably like given from Corsair)? I've never overclocked RAM myself, always just loaded D.O.C.P. / XMP profiles, is there anything else besides setting lateny, clock and voltage I have to do?
    Many thanks in advance!
    Drunkencookie
    New ROGer Array fred_ PC Specs
    fred_ PC Specs
    MotherboardASUS TUF GAMING B5550-PLUS
    ProcessorAMD Ryzen 3700
    Graphics Card #1ASUS Strix GTX 1660 SUPER
    OS Windows 10 64 bits
    Oct 2020
    2
    B550 TUF Gaming issue with DOPC
    Hi, I am having the same kind of issue with a B550 TUF Gaming MB
    no problem at all if I don't use the DOCP setting to change my corsair LXP memory settings to 3600 MHz
    if I use DOPC my system is having sometime some unattended hard restart like a power failure. I think Mainly when the system is idle.
    Contacted the ASUS support about that but with no help at all for the moment.
    I am now testing the last bios (1804) released few days ago.
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    166
    2,151
    Quote Originally Posted by fred_ View Post
    Hello,
    It depends what is contained in the XMP profile by the memory vendor. Set the voltage, timings and frequency manually and see if the issue persists. Tuning of the VSOC rail is often needed depending on the CPU sample.
    fred_ PC Specs
    Oct 2020
    2
    BIOS Version 1804
    Quote Originally Posted by Silent Scone@ROG View Post
    Hello,
    I ve updated the BIOS to the Version 1804 than 1 month ago and since I don't have any more issue.
    So I guess it was more related to the BIOS.
    Thanks
