Results 1 to 10 of 10
    New ROGer Array Betroz PC Specs
    Betroz PC Specs
    MotherboardAsus Maximus XI Apex
    Processori9 9900K
    Memory (part number)F4-3200C14D-32GTZR
    Graphics Card #1Asus Strix 2080Ti OC
    MonitorAsus PG279Q
    Storage #1Adata SX8200 PRO
    Storage #2Adata SX8200 PRO
    CPU CoolerCorsair 150i PRO
    CaseLian Li O11 Dynamic
    Power SupplyCorsair AX860
    Mouse Logitech G502
    Headset Sennheiser 660S
    OS Windows 10
    Betroz's Avatar
    Nov 2019
    6
    Maximus XI Apex and Dimm.2 M.2 SSD speed limit clarification.
    Hi guys
    I recently bought myself two Adata SX8200 PRO SSDs and plugged them in the Dimm.2 module. Ran a CrystalDiskMark bench and noticed that on one of the M.2 SSDs the sequential read and write performance was half of what the other SX8200 PRO had. About ~1750 MB/s. I checked my settings in the BIOS, but could not find anything wrong there. I then confirmed the performance difference with Adata SSD Toolbox, one SSD runs at Gen3 4X mode and the other at Gen3 2X.
    My system specs : XI Apex with BIOS 1105, 9900K, 32GB RAM, singel 2080Ti and just one other storage device, a Samsung 860 EVO SATA SSD. Windows 10 1903 fully updated, and using Microsoft NVMe driver.
    Is this caused by a BIOS bug or is it a Z390 platform limitation?
    Thanks for any reply
    ROG Guru: Yellow Belt Array Ch3vr0n PC Specs
    Ch3vr0n PC Specs
    MotherboardAsus Maximus XI Formula
    ProcessorCore i9 9900k @ 4.7GHZ (XMP)
    Memory (part number)CMD16GX4M4B3200C16-ROG
    Graphics Card #1Asus Strix GTX 1080 A8G
    Sound Cardon board
    MonitorASUS VG278HR & ASUS VK278Q
    Storage #1Samsung 960 Pro 512 GB & 970 EVO 2TB
    Storage #23X HGST 10TB, 1x HGST 4TB
    CPU CoolerScythe Mugen 5 PCGH
    CaseCooler Master Cosmos II
    Power SupplyCorsair AX860i
    Keyboard Corsair k95 RGB Platinum
    Mouse Corsair M65Pro RGB
    Headset Corsair Voide Wireless SE
    Mouse Pad Corsair MM300
    Headset/Speakers Logitech Z-906
    OS Windows 10 Pro x64
    Network RouterNetgear XR500
    Accessory #1 Xbox One Elite Wireless Controller
    Accessory #2 2X Corsair LL140, 4x Corsair LL120
    Accessory #3 1x Corsair LED RGB Pro expansion kit
    Ch3vr0n's Avatar
    Nov 2012
    180
    Probably a misconfiguration in the bios (rather than a bug). It's definitely not a Z390 platform limitation, at worst it's the dimm.2 implementation of asus, this is not something specified in the Z390 chipset i think.
    I'm running 4 standard HDDs, 1 samsung 970 pro, 1 960 pro and 3 optical drives all at full speed.
    Betroz PC Specs
    Processori9 9900K
    MonitorAsus PG279Q
    Mouse Logitech G502
    OS Windows 10
    Betroz's Avatar
    Nov 2019
    6
    Quote Originally Posted by Ch3vr0n View Post
    On the XI Apex board?
    ROG Guru: White Belt Array Carlyle2020 PC Specs
    MotherboardAsus Maximus XI APEX w/o vrm heatsink
    Processor8086K/@5.1/1.305/LLC5
    Memory (part number)Corsair LPX 4000 CL19@17.21.41/560/2T
    Graphics Card #1OOO RTX 2080 Ti FTW3 ULTRA
    Graphics Card #2GTX 1060
    Sound CardOOO Xonar STX modified
    Monitor21: 9 LG 34 inch / flat
    Storage #11TB 960evo
    Storage #22TB 970evo plus
    CPU CoolerNoctua NH-D15
    CaseSilverstone FT2 +200 bucks of sounddampening
    Power SupplySeasonic TX-850 RMAed the prime tita1000w
    Keyboard Cherry KC 1000 / OOO CORSAIR K63 + lapboard
    Mouse MX Master 2S
    Headset Sennheiser PC360 + Philips X2HR
    Headset/Speakers klipsch 4.1 pc speaker /cooling modified
    OS Win 10 64bit
    Network Routeryeah right...
    Accessory #1 Silverstone EBA01 headphone stand / black
    Accessory #2 radio Keyfob to turn on and off from Garage
    Accessory #3 Adata USB3.1 512Mb SSD @480Mb ul/dl
    Mar 2018
    17
    106
    It must be a wrong Bios setting since i get full speed on both SSDs.
    Confirmed via the tool you suggested.
    I checked my Bios. I didn't find something to point out except that "Hyper M.2 xxx" should be off since this is a pcie-slot extension card setting as far as i know.
    If you can't find the setting please post Bios pics and i will compare.
    Rgds
    Carlyle
    Betroz PC Specs
    Processori9 9900K
    MonitorAsus PG279Q
    Mouse Logitech G502
    OS Windows 10
    Betroz's Avatar
    Nov 2019
    6
    Quote Originally Posted by Carlyle2020 View Post
    Rgds
    Carlyle
    That setting is off. I tried to set it on one time, and the system would not boot. Had to reset cmos.
    ROG Guru: Yellow Belt Array XYchromosone PC Specs
    MotherboardASUS Maximux XI Extreme [BIOS 1302]
    Processori9 9900K
    Memory (part number)G-Skill Trident Z RGB CL17 3600MHz 32GB [4x8]
    Graphics Card #1ASUS ROG Strix Gaming GTX1080Ti 11GB
    MonitorAOC AGON AG271QG 27" 165Hz
    Storage #1Samsung 970 Pro NVMe 1TB M.2 SSD
    CPU CoolerThermaltake Floe Riing 360 Premium AIO
    CaseFractal Design Define R6 Black
    Power SupplyCorsair AX1600i
    Keyboard RAZER Blackwidow X Tournament Chroma
    Mouse RAZER Lancehead [ambidextrous] Chroma
    Headset Sennheiser RS165 Wireless
    Headset/Speakers Sennheiser CX 100 inner ear headphones
    OS Windows 10 Pro x64 + UbuntuStudio 18.04
    Network RouterASUS DSL-AC68U on ADSL2+, Technicolor DJA0230TLS Gateway NETGEAR CABLE ADAPTER CM450
    XYchromosone's Avatar
    Dec 2015
    30
    201
    Quote Originally Posted by Betroz View Post
    I Believe it would not boot with the setting set on is because it disables some sata ports which the SSD must rely on. I did something similar in my XI Extreme where I enabled 4X PCIe for the SSD M.2_1 in the motherboard. It disables 2 sata ports to get that double bandwidth. But the system would not boot so I had to revert back to 2x.
  7. #7
    Betroz PC Specs
    Processori9 9900K
    MonitorAsus PG279Q
    Mouse Logitech G502
    OS Windows 10
    Betroz's Avatar
    Nov 2019
    6
    Quote Originally Posted by XYchromosone View Post
    I believe I have found the cause of the problem, allthough I don't understand why it got fixed this way. Since I only have one SATA SSD in my system connected to port 1, I have had the other 5 ports disabled in the BIOS. For the sake of troubleshooting I now enabled ALL of them, ran a new CrystalDiskMark bench on the second drive, and now the performance is where it should be.
    I would like Asus to explain why this is so. It would be great
  8. #8
    Ch3vr0n PC Specs
    Sound Cardon board
    Ch3vr0n's Avatar
    Nov 2012
    180
    My entire post only addresses your "is this a platform issue". It's not, as i'm using that same platform (different board though) and i'm running all that hardware. So it's not a chipset limitation. Either as i said bios misconfiguration, or at worst board limitation. It aint exactly the same board as mine
  9. #9
    Mouse MX Master 2S
    OS Win 10 64bit
    Mar 2018
    17
    106
    ... Isn't there a mention in the manual about ports 1, 5 and 6 sharing resources ?
  10. #10
    Betroz PC Specs
    Processori9 9900K
    MonitorAsus PG279Q
    Mouse Logitech G502
    OS Windows 10
    Betroz's Avatar
    Nov 2019
    6
    I searched the manual now, and could not find anything about that. Anyway all the SATA ports must be enabled in BIOS for both M.2 SSDs to run at full speed in that Dimm.2 module...for some reason. One would think that disabling ports would free up lanes from the PCH, but apparently not.
Tags for this Thread
