Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    New ROGer Array
    Jun 2018
    11
    GL503 VM Drop FPS problem,save my son
    I bought ROG strix 2 GL503 VM, it always drop FPS when i play games and it is very serious. I have been checked it in the service center but they found nothing. GPU is functions well:
    1. I have never saw my CPU reach 80% of usage. The highest is 60%
    2. My GPU is GTX 1060 6GB, it seems like is GTX660 NVIDIA
    Please help on how to solve or stop dropping FPS on my laptop
    ROG Guru: Yellow Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega
    ProcessorIntel® Core™ i9-9980XE CPU @ 3.00GHz
    Memory (part number)Corsair LPX Vengeance DDR4 DRAM 2666MHz 128 GB
    Graphics Card #1Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB
    Storage #2Samsung 970 Pro 1 TB
    CPU CoolerROG Ryujin 360
    CaseThermaltake View 71 TG
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot)
    Mar 2019
    168
    There is usually one cause of your problem. Your computer is throttling (slowing itself down) as a computer health/safety mechanism because your components, such as your cpu and/or gpu are heating up too much. Are your vents clear of dust? If so, you can always lower your computer and/or in-game performance settings. In my case the chief way to do that is to limit the FPS to at or below your screen refresh rate (in my case I limit FPS to 30 or 40 most of the time). There are a host of other potential settings you can adjust, such as your Windows power settings and things like V-sync, etc.
    Banned Array
    Oct 2019
    40
    Quote Originally Posted by cey8923 View Post
    install msi afterburner or some other software and provide us information how high your temps are while playing. it seems your machine is temp throttling.
    New ROGer Array
    Jun 2018
    11
    Quote Originally Posted by chumacher View Post
ID:	82978Click image for larger version.
ID:	82979 this is a test for FurMark ROG Edition x64 but so 2 min FPS killed already
    New ROGer Array
    Jun 2018
    11
    Quote Originally Posted by Super Gnome View Post
    What in my mind now is most probably is the fan problem. I will go check it again the fan and heat dissipation in the service center
    But i saw the two fans is joint with the heat dissipation board. It is not easy to get a new one right?
    Banned Array
    Oct 2019
    40
    you are using VERY OLD driver.
    https://www.guru3d.com/files-get/gef...ownload,4.html
  7. #7
    New ROGer Array
    Jun 2018
    11
ID:	83016Click image for larger version.
ID:	83017Even if I have updated the driver, I got the same test results.
  8. #8
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    46
    490
    The GPU isn't overheating, but what about the CPU?
  9. #9
    New ROGer Array
    Jun 2018
    11
    Quote Originally Posted by FULLMETALJACKET7 View Post
ID:	83022Click image for larger version.
ID:	83023 The cpu is overheating, when i play game(Assassin's Creed Origins), for MSI Afterburner.
  10. #10
    Mar 2018
    46
    490
    For troubleshooting, go to the windows power options > change advanced power settings > processor power management, set the "maximum processor state" to 95%. See if that brings the CPU temperature down. If it does, we will try something else using Throttlestop.
