Results 1 to 9 of 9
    ROG Enthusiast Array akrovatis PC Specs
    akrovatis PC Specs
    MotherboardAsus ROG Zenith Extreme Alpha
    ProcessorAMD Ryzen Threadripper 1920X
    Memory (part number)G-Skill F4-3200C14Q-32GTZRX
    Graphics Card #1Zotac GeForce RTX 2060 6GB AMP
    Sound CardAudient iD14 MKII
    MonitorAOC Q3279VWFD8
    Storage #1Samsung 970 Evo 1TB
    CPU CoolerDeepcool Fryzen
    CasePhanteks Enthoo Evolv X Glass Galaxy Silver
    Power SupplyCorsair AX 850
    Keyboard Corsair VENGEANCE® K95 RGB
    Mouse Logitech G502 Lightspeed
    Headset Beyerdynamics 770 Pro
    OS Windows 10 Pro
    akrovatis's Avatar
    Jul 2019
    35
    Nahimic Service full of problems
    I had problem with fullscreen mode on a game. It was always on window mode and whenever I was trying to change the resolution it was freezing. I did a clean boot on windows and after disabling and enabling the services, that Nahimic Sercvice was causing the problem. After a quick search on internet I found out lots of complaints about this Nahimic Service. I wonder now what to do to delete it. Any ideas?
    ROG Guru: Orange Belt Array 1mluer PC Specs
    1mluer PC Specs
    MotherboardMaximus XII Apex
    ProcessorI9-10900k
    Memory (part number)Gskill Trident Royal 4400
    Graphics Card #1ROG Matrix 2080 ti
    Sound Cardbuilt in
    MonitorASUS Swift PG348Q
    Storage #1Samsung 970 EVO Plus Raid
    Storage #2Samsung 970 EVO Plus Raid
    CPU CoolerRyujin 360
    CaseInWin 909 Silver
    Power SupplyROG Thor 1200p
    Keyboard ASUS ROG Claymore
    Mouse Logitech G900
    Mouse Pad ASUS ROG Baltheus
    Headset/Speakers Bose Computer Set with Sub
    OS Windows 10 Pro
    Network RouterNightHawk RAX200
    Accessory #1 TT Riing Plus
    Accessory #2 Blue Microphone
    Feb 2017
    42
    421
    I didn't delete anything. I just went into task manager under startup, right clicked the 2 nahimic services and disabled them. my problem solved.
    InWin 909 Silver RGB build
    i9-10900k
    ROG Maximus XII Apex
    ROG Matrix 2080 ti
    Gskill Trident Royal 4400 16g
    Everything overclocked and love it.
    ROG Awesomeness !!!!
    akrovatis PC Specs
    OS Windows 10 Pro
    akrovatis's Avatar
    Jul 2019
    35
    Quote Originally Posted by 1mluer View Post
    I want to have Normal Startup and not Selective Startup. I had to uninstall Realtek drivers that were been prompted by Asus Armoury Crate.
    I searched the internet and found so many problems that NahimicService.exe causes. I wonder why Asus and Realtek still using this crap.
    I paid 600€ for a motherboard that is causing so many problems to me. First it was Armoury Crate that I couldn't install properly, then the RGB Aura, which causes conflicts when iQue of Corsair is enabled. Not to mention stupid applications like Fan Expert. All are useless stuff that causing problems. Not a single good application on this motherboard.
    ROG Guru: Orange Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula
    ProcessorIntel® Core™ i9-9980XE / AMD 3950x
    Memory (part number)Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH
    Graphics Card #1Asus 2080 Turbo / Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 Turbo / Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500
    Storage #2Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2
    CPU CoolerROG Ryujin 360 / ROG Ryujin 360
    CaseThermaltake View 71 TG / Thermaltake View 31
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
    Mar 2019
    31
    440
    Not sure if this'll help, but in my case Nahimic Service was asking for permission on startup twice--which was annoying. Now whether or not this had to do with Armoury Crate failing to do much functionally at all, but that was my guess. To solve the problem (and remove junk that didn't work in the first place in any way) uninstalling Armoury Crate, and kissing it goodbye and good riddance solved the problem.
    akrovatis PC Specs
    OS Windows 10 Pro
    akrovatis's Avatar
    Jul 2019
    35
    Quote Originally Posted by MoKiChU View Post
    Strictly follow the ROG SS3 tutorial/drivers here (FIRST INSTALL/CLEAN INSTALL, be careful not to forget what is in red) : https://rog.asus.com/forum/showthrea...HD-Audio-(UAD).
    I tried It and downloaded the drivers that gave from MEGA. It didn't work. I had to uninstall Realtek drivers.
    Now my system runs fine without this NahimicService.exe file.
    New ROGer Array
    Aug 2019
    4
    Quote Originally Posted by akrovatis View Post
    Yea, nahimic is practically malware. Thankfully it's completely useless, as it only affects the equally useless Sonic Studio and Radar, so you can simply disable the service and you're done.
  7. #7
    ROG Member Array
    Aug 2020
    This program is problematic, when the service is running or when I have it enabled upon start up; all I get is countless memory errors. Immediately when it's disabled these error disappear, but how do I remove this program from running ?
    I read that it's a virus, other say it's an audio related device driver.
  8. #8
    New ROGer Array
    Jan 2020
    3
    I recently manually updated windows to the 2004 version and got some major performance issues. About 1 minute for Firefox, chrome etc to launch! I rolled back to earlier Windows and it was working fine again.
    Yesterday Windows updated automatically to 2004 and the problem was back.
    Googled and found that it could be caused by a driver from ASUS. I stopped the service called Nahimic Service and the computer was fine.
    I just wanted to point this out, that the cause of the problem is the Nahimic driver from Asus! I've no idea how it came into my system but I might have installed some of their crappy software some year ago. (I'm using a ASUS Z390-F motherboard - My next motherboard will probably not be an ASUS product)
    Cheers
  9. #9
    New ROGer Array
    Jan 2020
    3
    Haha, just read your post and I couldn't agree more! I tried some of their applications about a year ago and they were all just garbage with a horrible GUI skin! I think ASUS should continue with their hardware and stop working on software because that's where they are really annoying. I personally think the badly written software is hurting ASUS badly.
