Asus NODE Hardware Interface
deuscovrigus
Hello I have a build using the Asus ROG RAMPAGE VI Extreme Omega (R6EO) and this has 1x NODE Connector (12-1 pin NODE), connector #20 in the manual. The description says that it can connect a compatible PSU. I have purchased the ROG THOR 1200W and am wondering if it comes with a cable that can connect to the NODE interface. The Thor says it only includes a RGB cable. Does ROG Thor work with NODE at all? It sounds like it might be a compatible PSU.
Thanks all!
0 REPLIES 0
