Results 1 to 2 of 2
    ROG Junior Member Array
    May 2018
    1
    CPU Fan is Stopping!!!
    Hey guys...
    I'm using Rog CrossHair VI Extreme long time ago...
    Installed AI SUite and Fan Expert 4. I Upgraded bios 7403...
    I've been having the same problem since the day I bought it.
    MY CPU Fan Stopping... I Searched, googled, tried https://rog.asus.com/forum/showthrea...-Xpert-Problem this solution. But not find any solution...
    Thanks for help and sory for my english ^_^
    OctalCore AMD Ryzen 7 2700X, 4000 MHz (40.25 x 99)
    Asus ROG Crosshair VI Extreme (3 PCI-E x1, 3 PCI-E x16, 2 M.2, 4 DDR4 DIMM, Audio, Video, Gigabit LAN, WiFi)
    AMD X370, AMD Taishan, AMD K17 IMC
    DIMM1: G Skill TridentZ RGB F4-3200C14-8GTZRX 8 GB DDR4-3200 DDR4 SDRAM (14-14-14-34 @ 1600 MHz)
    DIMM2: G Skill TridentZ RGB F4-3200C14-8GTZRX 8 GB DDR4-3200 DDR4 SDRAM (14-14-14-34 @ 1600 MHz)
    DIMM3: G Skill TridentZ RGB F4-3200C14-8GTZRX 8 GB DDR4-3200 DDR4 SDRAM (14-14-14-34 @ 1600 MHz)
    DIMM4: G Skill TridentZ RGB F4-3200C14-8GTZRX 8 GB DDR4-3200 DDR4 SDRAM (14-14-14-34 @ 1600 MHz)
    AMI (08/20/2019)
    ROG Guru: Orange Belt Array
    Apr 2019
    19
    267
    Quote Originally Posted by volkanmanioglu View Post
    Hey guys...
    AMI (08/20/2019)
    Have you tried a another fan connector? *
