Results 1 to 8 of 8
    ROG Member Array iTesla PC Specs
    iTesla PC Specs
    Laptop (Model)PC Assembled by me
    MotherboardAsus Strix Z270F Gaming
    ProcessorIntel i7-7700K 4.5Ghz
    Memory (part number)KHX2400C15/16G | 4pcs = 64GB
    Graphics Card #1Asus GTX1070 Dual O8G
    Sound CardRealtek High Definition Audio
    MonitorSamsung U32J59xUQ 4K
    Storage #1Intel SSD 760p Series PCIE/NVMe M2.1 1TB
    Storage #2Intel SSD 600p Series PCIE/NVMe M2.2 1TB
    CPU CoolerDeepcool Captain120 EX
    CaseNZXT Source S340 White
    Power SupplyCorsair RM1000i
    Keyboard AZIO Retro Classic Copper
    Mouse Razer Mamba Hyperflux
    Mouse Pad Razer Firefly Hyperflux
    OS Windows 10 Pro 64Bit
    Accessory #1 Oculus Quest
    Accessory #2 Nvidia Controller Gen2
    iTesla's Avatar
    Jan 2018
    32
    12
    Exclamation Motherboard thermistor possible faulty?
    Hello
    If someone know if this is normal, temp 5 is not showing any temp.
    As i work with iPhones i know what are this thermistors but i was unable to detect them on my Asus motherboard, they are possible having other package or placed in special locations on motherboard, a schematic would be useful.
    I have observed this long time ago after i first installed the motherboard, was thinking maybe i have touch with screwdriver during assembling into case, not sure cause investigation under microscope did not reveal any damaged part, have observed only nostuff components from factory.
    Any help is appreciated, thank you.
    All problems are created artificially cause selling solutions is profitable.
    iTesla PC Specs
    iTesla's Avatar
    Jan 2018
    32
    12
    Lightbulb Thermal Motherboard View
    I have take a photo with thermal camera, will have a look again when i will replace the case fans with new ones and try detect this thermistors locations to see for what components/functions they detect heat.
    Rockford
    Guest
    is the gun pointed at the motherboard chipset heatsink or the PCB of the GPU?
    it is thermal interference in the image, use different angles
    Temp sensor 5 can very well be the 2 pin temp sensor header on the motherboard (not connected)
    Welcome to the forum...
    ROG Guru: Green Belt Array
    Feb 2019
    118
    543
    unfortunately I dont believe there is a catalog of what is what on 3/4 of the temp sensors.
    Rockford
    Guest
    The T-sensor header is not named in software (its J Doe), its however named in bios (should be)
    It can be named in AI Suit also
    This is not a big thing to lose sleep over seriously, you can connect a 10k? probe to the header if you have one, and you should get a reading in Bios and software
    Some folks is using that header for monitoring water temperature (custom water cooling)
    iTesla PC Specs
    iTesla's Avatar
    Jan 2018
    32
    12
    Quote Originally Posted by Rockford View Post
    Yes that is pointed to chipset heatsynk.
    Then this Temp 5 is for sure that 2 pin conn because i doubt i damaged anything on the motherboard.
    Thank you for clarification!
  7. #7
    ROG Junior Member Array
    Jun 2014
    1
    My Temp Sensor 5 is acting wonky, too. I believe it is under the Chipset Heatsink, which incidentally is under my video card heat vent. My sensor was giving me intermittant values of 0, and 127. I thought it was buggy but then my video card must have been failing and caught fire right above that heatsink. I had SLI, now I moved my other video card in that same spot and I'm getting those readings again, while running intensive gaming. The video cards are about 5 years old.
  8. #8
    iTesla PC Specs
    iTesla's Avatar
    Jan 2018
    32
    12
    Quote Originally Posted by Davrada View Post
    This is most likely that thermal 2 finger connector, i was getting the same as you weird readings and this is because the fingers are exposed.
    You should not worry about it, as i do myself.
Tags for this Thread
