Results 1 to 8 of 8
    New ROGer Array
    Jun 2019
    xmp Rampage VI Extreme Omega , How make it work ?!
    delete
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS x99 sabertooth & x299 Rampage VI Apex
    Processori7-5930k & i9-9940x
    Memory (part number)Trident-Z 3200C14 & Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block & Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Coolerx99 2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 & EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum & Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Heatkiller 4 Pro copper plexi/Optimus Foundation copper plexi
    Accessory #2 Mayhems Biocide and Inhibitor with distilled water
    Accessory #3 Mayhems 3/8-5/8" clear soft tubing
    ThrashZone's Avatar
    Oct 2017
    23
    365
    You don't say what frequency or exact memory kit you're using
    Last couple bios for 99..x compatibility has messed up xmp profiles at least for me anyway using trident-z 3600C16 = 16-16-16-36
    I had to go manual and tweak timings to get it to perform better.
    ROG Guru: Yellow Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega
    ProcessorIntel® Core™ i9-9980XE CPU @ 3.00GHz
    Memory (part number)Corsair LPX Vengeance DDR4 DRAM 2666MHz 128 GB
    Graphics Card #1Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB
    Storage #2Samsung 970 Pro 1 TB
    CPU CoolerROG Ryujin 360
    CaseThermaltake View 71 TG
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot)
    Mar 2019
    168
    Maybe a stupid question, but are your ram sticks pushed all the way in? I had this once as a problem, lol. Also, was it one kit or two, or four. I've never had a problem with using multiple different kits of the same model, but others have.
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    23
    365
    It has a weird 2nd xmp profile looks like 2666 x 2 ?
    But yeah hynix memory is what has been having most issues
    I'd clear cmos and try manually setting default timings and frequency
    Dimm voltage 1.36v will be fine
    Get yourself asrock memory configurator for x299 so you can see all the timings/ secondary/... the set is using in windows
    Or just read this op and post there for expert suggestions
    https://www.overclock.net/forum/5-in...ty-thread.html
    ROG Guru: Orange Belt Array vmanuelgm's Avatar
    Sep 2013
    22
    268
    Omega likes B-Die single sided modules, a total of eight cos of T-Topology. So 8x8GB B-Die should reach the best performance.
    tRC is not usually displayed in Asus Bios's. Other manufacturers like Gigabyte (some boards) display it and let force it, but not Omega.
    Omega, 7980xe, G.Skill 3600, 2080Ti, SM951 256, 970 PRO, 860 EVO
    Intel 750, WD SN750 Black, 840 Pro, 2xSkyhawk 4TB, 7200.14, 207EBK
    EVGA T2 1600, Silverstone TJ11, Custom LC. @Acer Predator x34
    Feb 2019
    23
    145
    Ive had zero issues with Samsung. I think its the hynix getting you.
    The biggest part of the picture that I did not see.......Is this a single kit of 8x 16GB or a culmination of smaller kits like 2 different 4x 16 kits? Thats another flag.
    Lastly I actually opted for 64GB of 8x8GB Corsair dominator Kit (its labeled and sold as X299 kit) as Ive always had better luck as a whole with 8GB sticks over 16GB sticks.
    Memory process during manufactur is to bin like sticks then out of that bin those with similar performance and test them together as a kit. If they are not then probability of getting them to run above Jdec standard of 2133 is greatly reduced. Not saying impossible but not at all likely and the faster you go the less likely it is. I cranked a 3600 C18 kit to 3800 C16 very easily. Set it to XMP then went in and ran it up to 3800 and dropped the CL to 16, Bam and done. Of course setting voltage to 1.35 as it doesn't do that by itself and no kit that I know of will run above 2133 art the default 1.2V
  7. #7
    Sep 2013
    22
    268
    Quote Originally Posted by Mreksoll View Post
    Problem is , omega unstable some times ( not 100% of time ) i can reboot 5 times , even cold start , and randomly can ern bug. With rtls and iol i find some solution , but not only memory hv problem , all voltages is bugged and it bad work with 7980xe memory controler even at deffaul if not make sa and io 1.1 ( what give to sa 1.168 and to io 1.13). Its can work perfect then blue screens and errors at prime 95.
    at my old prime deluxe memory was stable with deffault sa and io , maybe there need dissable some 3nd timing optimization .
    there exist some turnaround time optimization ( its at auto )
    Who knows what it do ?
    There is many setting what unknow what to do. What hv description its good but most dont hv and if click at theme only says the same as it named.
    Please post captures of your inbios memory setup to see all the values applied...
  8. #8
    Sep 2013
    22
    268
    Cpu cores and mesh at stock??? Seems so...
    50 degrees at stock in bios??? Very high temperature for cpu in this case...
    1.20v for vccio and system agent for 3000MHz??? Quite high, even for 128GB. U should decrease system agent to 0.900 and if it is not enough, raise it slowly until u find stability. If u push more voltage to system agent than needed, unstability comes up... Vccio should not go above 1.05v unless u are pushing your overclock to a higher level. Vccin at auto with a value of 1.96v for stock is quite high, 1.8v should be enough or even less.
    Then u can try to lower some of the secondary and tertiary dram timings. U can also fix dram clock period to a value of 13 or 14 to see if it helps. Set turnaround optimization to auto if u want to be able to fix tertiary timings. U can set it to disabled to a more conservative autoconfiguration, but manual settings will be overrided in some cases.
    Disable MemOK with the onboard switch.
    And to test memory stability, I prefer HCI Pro under Windows (500% coverage without errors or higher) or GSAT under Linux (2 hours without errors).
