Results 1 to 2 of 2
    New ROGer Array
    Nov 2019
    11
    Power off external USB hub
    Just got an Asus Rog Strix 450 F mobo....Can someone tell me where (in the BIOS presumeably) , to go and what setting to tweak to have my external USB 9 port hub power itself off whenever the pc is powered off?
    Thanks!
    New ROGer Array
    Nov 2019
    11
    34
    Quote Originally Posted by JohnGalt View Post
    Thanks!
    open command prompt as administrator and type "shutdown /s /f /t 0" without quotes
    or press shift while shutting down using Win 10 GUI
    Win 10 is using hybrid shutdown as default
    Disable Fast startup if you must..
Tags for this Thread
