Results 1 to 7 of 7
    New ROGer Array akrovatis PC Specs
    akrovatis PC Specs
    MotherboardAsus ROG Zenith Extreme Alpha
    ProcessorAMD Ryzen Threadripper 1920X
    Memory (part number)G-Skill F4-3200C14Q-32GTZRX
    Graphics Card #1Zotac GeForce RTX 2060 6GB AMP
    MonitorAOC Q3279VWFD8
    Storage #1Samsung 970 Evo 1TB
    CPU CoolerDeepcool Fryzen
    CasePhanteks Enthoo Evolv X Glass Galaxy Silver
    Power SupplyCorsair AX 850
    Keyboard Corsair VENGEANCE® K95 RGB
    Mouse Microsoft Comfort Mouse 3000
    Headset Beyerdynamics 770 Pro
    OS Windows 10 Pro
    akrovatis's Avatar
    Jul 2019
    24
    ASUS ROG Zenith Extreme CPU Code 00
    I have installed some updates from Armoury Crate. Asus Framework Service, Asus Core SDK, Asus ROG Zenith Extreme Alpha (HTML / HAL / AURA Kit / Device SDK)
    After restarting my system, I got a CPU "Code 00" on the screen of the motherboard.
    Well, the problem seems to have been solved after a few attempts of restarting and applying optimized defaults in the Bios. The only thing it changed was after Hybernate, Stealth Mode ON. I have installed the iQue Software of Corsair for my keyboard and sometimes with the combination of AURA kit does some crazy stuff. For example when I load "Rainbow Mode" one of my RGB memory sticks has different color from all the others.
    ROG Guru: Brown Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    I wouldn't run 2 or more differing RGB software on Zenith Extreme and Zenith Extreme Alpha. The software can clash with one another, also the Super IO chip can have issues with software which accesses it and does not use a feature called ASUS WMI.
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    akrovatis PC Specs
    OS Windows 10 Pro
    akrovatis's Avatar
    Jul 2019
    24
    Quote Originally Posted by gupsterg View Post
    So, how am I supposed to have my keyboard working without its software? This is insane! The only solution is to choose one of them?
    akrovatis PC Specs
    OS Windows 10 Pro
    akrovatis's Avatar
    Jul 2019
    24
    It happened again. Error Code 00
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    Quote Originally Posted by akrovatis View Post
    Sorry I have no solution to share on this, I just thought I'd give you the information.
    Others have had this issue, link. No idea on solution.
    I have used 1950X & 2920X with ZEA and not encountered this issue. Each time I also did not even use the AMD torque tool, but just tightened socket screws with normal torque bit and screwdriver.
    I have also used 2 sets of RAM now with ZEA, F4-3200C14Q-32GTZSW & F4-3200C14Q-32GVK and not encountered issue.
    Sorry no solution I can share.
    ROG Guru: Yellow Belt Array Dimitrios1971 PC Specs
    Laptop (Model)GX700VO 1TB SSD + 64GB RAM
    MotherboardASUS ROG ZENITH EXTREME ALPHA
    ProcessorAMD Ryzen Threadripper 2950X
    Memory (part number)F4-4000C18Q2-64TZR (3333MHz)
    Graphics Card #1ROG Strix GeForce® GTX 1080 Ti OC-Edition
    MonitorROG Swift PG348Q Gaming
    Storage #13 x Samsung SSD NVMe 960 PRO 1TB Raid0
    Storage #24 x Samsung SSD NVMe 970 PRO 1TB Raid0
    CPU CoolerCOOLER MASTER MasterLiquid ML360 RGB TR4 Edition
    CaseROG Strix Helios
    Power SupplyASUS ROG THOR 1200P
    Keyboard ROG Strix Scope Deluxe & ROG Strix Scope TKL Deluxe
    Mouse 2 x ROG Chakram
    Headset ROG Throne Qi
    Mouse Pad ROG Balteus Qi RGB & ROG Sheath
    Headset/Speakers 2 x ROG Strix Go 2.4 & ROG Strix Fusion 700
    OS Win10_x64
    Network RouterFRITZ!Box 6660 Cable
    Accessory #1 BW-16D1H-U PRO
    Accessory #2 ROG STRIX ARION & Asustor AS6404T
    Accessory #3 2 x HYPER M.2 X16 GEN 4 CARD
    Dimitrios1971's Avatar
    Apr 2015
    69
    133
    OLD
    NEW
  7. #7
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    127
    1,943
    Consider reseating the CPU and CPU cooler.
