Results 1 to 5 of 5
    ROG Guru: Yellow Belt Array Baio73 PC Specs
    Baio73 PC Specs
    MotherboardAsus ROG Crosshair VIII Formula BIOS 3402
    ProcessorAMD Ryzen 3900XT
    Memory (part number)2x8 Corsair 4000C19D
    Graphics Card #1Sapphire RX 5700XT
    MonitorLG 34GK950F
    Storage #1Samsung 980PRO 512Gb NVMe
    Storage #2WD Black SN850 2Tb NVMe
    CPU CoolerCorsair H150i Elite Capellix
    CaseLian Li 011D XL
    Power SupplyCorsair AX860i
    Keyboard Logitech G513
    Mouse Logitech G903 + Powerplay
    Headset G933 Artemis Spectrum
    Mouse Pad Corsair MM 700 RGB
    Headset/Speakers Logitech G560
    OS Windows 10 64bit
    Network RouterLynksys EA6500
    Accessory #1 Corsair Commander Pro
    Accessory #2 10xCorsair QL120 RGB fan
    Jul 2014
    11
    157
    Aura and case light problem
    Hi there,
    I'm using a CH7HWF along with a LIAN LI 011 Dynamic XL case.
    This case has a front led strip that should be compatible with Asus Aura:
    I've connected the case's 3-pin cable to the ADD_HEADER1 of the mobo but still does not work.
    Should I set something within ? Aura version is v1.07.71.
    Thanks
    Baio
    CASE Lian Li 011D XL CPU AMD Ryzen 3900XT COOLER Corsair H150i Elite Capellix MOBO Asus ROG Crosshair VIII Formula RAM 2x8 Corsair 4000C19D PSU Corsair AX860i VGA Sapphire RX 5700 XT DISPLAY LG 34GK950GF AUDIO Logitech G560 SDD Samsung 970PRO NVVe 512Gb - WD Black SN850 2Tb NVMe NPUT Logitech G903 + Powerplay + Corsair MM700 RGB - G513
    ROG Member Array
    Apr 2016
    Quote Originally Posted by Baio73 View Post
    Hi there,
    Thanks
    Baio
    I will second this, I have the same case and the ASUS X570 crosshair and the case rgb lights are nowhere to be seen, I have to use the manual switch on the case IO
    Baio73 PC Specs
    MonitorLG 34GK950F
    CaseLian Li 011D XL
    OS Windows 10 64bit
    Jul 2014
    11
    157
    Quote Originally Posted by christofalee View Post
    Did you connect the case strip's header to the mobo?
    If so, open AURA and config a strip with 28 leds, than sync whatever effect you prefer anid finally push the upper front case button untill the strip shows the effect you chose.
    Here it wotked untill a couple of days ago, then the strip started to make a terrible effect*.
    For sure there is not a great compatibility with AURA and I had to write to LianLi assistance to have the infos…
    Baio
    *I set the mobo's RGB, RAM and strip to sync with breathing effect, but when the strip fades in ad out for a second it shows a rainbow effect, very annoying especially wihen the room is dark
    New ROGer Array bluestang PC Specs
    bluestang PC Specs
    MotherboardASUS ROG Crosshair VII Hero
    ProcessorRyzen 3900X
    Memory (part number)F4-3600C15D-16GTZ (2 kits)
    Graphics Card #1MSI Armor OC 1660ti
    Graphics Card #2MSI Armor OC 1660ti
    MonitorASUS VZ249H
    Storage #1Samsung 970 EVO 250GB NVMe
    Storage #22x WD Red 10TB (RAID1)
    CPU CoolerFractal Design Celcius S36
    CasePhanteks Enthoo Luxe TG
    Power SupplySeaSonic Focus Plus Platinum 850W
    Keyboard Logitech MK-710 Combo
    OS Windows 10 Pro
    Network RouterASUS RT-N66U
    Oct 2019
    41
    I have the CH7 and was thinking about hooking the case lights from my Phanteks Enthoo Luxe Tempered Glass to the MB to control. After reading this, I think I'll just use the button on the case to control them to match what I chose for the MB in Aura lol
    Baio73 PC Specs
    MonitorLG 34GK950F
    CaseLian Li 011D XL
    OS Windows 10 64bit
    Jul 2014
    11
    157
    Quote Originally Posted by bluestang View Post
    The difficult part is if you use some effect for the mobo (like breathing) that needs to be synched. With my case I can set the strip as breathing from the front panel button, but it will never light in sync with the rest.
    What you need (and Phanteks can tell you) is to know how many leds the strip is made of, put the value in AURA and then ... prey.
    Baio
