Results 11 to 20 of 28
12-14-2019 03:27 AM #11
- Join Date
- Dec 2011
- Reputation
- 11
- Posts
- 100
01-01-2020 03:33 PM #12
Jahmen PC Specs Laptop (Model) ROG G75VW Motherboard ROG Rampage VI Extreme Encore x299 Processor i9-10920x 3.5GHz Memory (part number) 64 GB Graphics Card #1 ASUS DUAL Ge Force RTX 2080 Ti DirectX 12 DUAL -RTX2080TI-O11G Monitor ASUS ProArt x3 Storage #1 M.2 1TB SSD Storage #2 M.2 1TB SSD CPU Cooler DEEP COOL Castle 360EX Case Corsair Graphite 780T (White) Power Supply CORSAIR HXi Series, HX1200i, 1200 Watt, 80+ Platinum Certified, Keyboard Logitech G-15 Mouse Logitech Trackball Headset Corsair Gamer Headset Mouse Pad None Headset/Speakers Corsair Handsfree Head set OS Windows 10 64bit Pro Network Router AT&T-Uverse Accessory #1 ASUS Hyper M.2 x16 Card V@ Accessory #2 X4 Intel Pro 7600p M.2 2280 256GB PCI-Express 3.0 x4 Internal SSD
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 23
Okay, just to be clear. I'm building the Asus ROG Rampage VI Extreme Encore Motherboard. The Manual said to use either both 8 pins or use one 8 pin with the 6 pin. It had a clear warning to use the 6 pin with the 8 pin if your running multiple Graphic cards or to use both 8 pin. It didn't mention anything about connecting power to both 8 pin and the 6 pin sockets (Basically connecting power to them all). So, my question to the community at large here, is won't connecting power to all of them damage the Motherboard? Or does it just provides the maximum amount of power to the motherboard it is designed to handle or use?
Perhaps off topic, I was trying find out how to buy the motherboards thermal sensor that the manual said I needed to purchase separately. Any clue?
01-01-2020 04:44 PM #13
Arne Saknussemm PC Specs Laptop (Model) Laptop?...No way! (Model?...Jun Amaki...yes way!) Motherboard ROG ZENITH II EXTREME Processor THREADRIPPER 3960X Memory (part number) TXBD48G4000HC18FBK Graphics Card #1 GTX Titan X Graphics Card #2 SLI is dead to me Graphics Card #3 Tri SLI is even dead to Nvidia Graphics Card #4 Quad SLI is dead to everybody especially my credit card Sound Card Xonar Essence STX Monitor ASUS ROG Swift PG279Q Storage #1 Samsung 970/960/950 PRO Storage #2 2x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs CPU Cooler Custom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock Case Nope!...Dimastech Easy XL...let it all hang out man! Power Supply Seasonic 1000 Platinum Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73) Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney! Headset ...firmly on neck Mouse Pad Mouse don't got his own pad man...lives with me Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition Network Router 56k modem Accessory #1 Umm...nice tie? Accessory #2 Err...belt? Accessory #3 3 accessories?! I'm not a girl!!
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,686
Yes RIVE had a 6 pin for the GPUs
The manual is quite clear...i don't know how so many fail to read it or fail to understand it.
EZ molex connection is for multi GPU
Order of importance:
Populate 8pin....
Populate both 8pins
Populate both 8 pins and 6pin
Maybe populate 8pin and 6pin if you are missing cables.
However...a PSU that could handle the board and all you throw at it should have all the cables to fully populate all connectors. if your PSU doesn't have the cables then you should probably question your hardware choices...
05-29-2020 10:31 AM #14
biTi71 PC Specs Motherboard ROG Rampage VI Extreme Encore Processor i9 10920X Memory (part number) G-Skill F4-4000C18Q2-64GTZR Graphics Card #1 Nvidia GTX 1080 Ti Graphics Card #2 Nvidia GTX 1080 Ti Monitor Asus PG278Q CPU Cooler cuplex kryos NEXT VARIO with VISION, PVD/.925 silver Case be quiet! Silent Base 801 Power Supply EVGA Supernova 1300 G2 Keyboard Ozone StrikePRO Mouse Razer Abysus Headset Sennheiser G4ME ONE OS Win10 Pro 64Bit Network Router Asus RT-N18U
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 3
I find it misleading to have a 6 pin power connector as a 6 pin Pci-E connector point fits into place. However, the polarity of the 6-pin Pci-E connector is the opposite of the polarity of the socket indicated in the manual. I think the Pci-E power connector can only be used if it is converted by reversing the polarity or using a commercially available converter
05-29-2020 06:42 PM #15
- Join Date
- Feb 2019
- Reputation
- 16
- Posts
- 101
ok be careful.
1. the 6 pin is a normal PCIe connector - confirmed.
2. the original user guide (paper) that comes with the board had the 6 pin connector illustrated as a ATX special 6 pin connector with reversed polarity compared to the PCIe 6 pin.
3. without much fanfare ASUS updated their user guide to Version E16039 in November! BUT DID NOT published it until April 10 wtf - look it up here: https://www.asus.com/us/Motherboards...lpDesk_Manual/ and in this user guide they have corrected the page with the illustration to correctly show a 6 pin PCIe connector.
So the confusion was real and not fake, but the end result is that it is a PCIe 6 pin connector, and I can confirm that 100% since I use that daily for months!
I can also confirm that a 6 pin ATX special cable do not work MB and the if you install one the MB will not boot (got that one last year before they bothered to publish a new user guide)
05-29-2020 06:58 PM #16
tistou77 PC Specs Motherboard Rampage VI Extreme Encore Processor 10980XE @4.6Ghz Memory (part number) G.Skill Trident Z RGB Royal 4x8Gb @4000 C16 Graphics Card #1 EVGA RTX 2080ti XC Ultra Sound Card Xonar Phoebus Monitor Dell U2417H Storage #1 Intel Optane 905P PCIe Storage #2 Samsung 970 EVO Plus CPU Cooler Watercooling Case Lian Li A77F Power Supply Seasonic Prime Ultra Titanium 1000W Keyboard Logitech LIK Mouse Logitech MX revolution OS Windows 10 Pro x64
- Join Date
- Apr 2012
- Reputation
- 109
- Posts
- 1,637
Weird, I saw using the 3 cables (2 8pin and 1 6pin) and no worries
It even seems that VRMs heat up a little lessSorry for my english
Case: Lian Li A77F
MB: Rampage VI Extreme Encore
CPU: i9 10980XE
RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
GPU: EVGA RTX 2080ti XC Ultra
PSU: Seasonic Prime Ultra Titanium 1000W
OS: Intel Optane 905P PCIe
DATA: Samsung 970 EVO Plus
SOUND: Asus Xonar Phoebus
05-29-2020 10:15 PM #17
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 3
05-29-2020 10:40 PM #18
- Join Date
- Dec 2015
- Reputation
- 10
- Posts
- 3
The improved version ...
05-30-2020 12:04 AM #19
- Join Date
- Apr 2012
- Reputation
- 109
- Posts
- 1,637
For 6pin, GND and 12v are "inverted", Asus has planned which original PSU cable to "connect" this 6pin ?
Case: Lian Li A77F
CPU: i9 10980XE
05-30-2020 11:21 AM #20
H-de PC Specs Motherboard WS-X299-PRO Processor Intel Core i9-10900X Memory (part number) KHX3200C16D4/4GX Graphics Card #1 EVGA RTX 2080 XC Ultra Gaming Sound Card HyperX(USB) CPU Cooler Noctua NH-U9S Case Fractal Design Define R6 White Power Supply Cooler Master v750 Keyboard HyperX FPS Blue-Switches Mouse Zowie FK1 Headset HyperX Cloud 2 Mouse Pad QCK+ OS WIndows 10 Build 2004
- Join Date
- Aug 2018
- Reputation
- 11
- Posts
- 36
